Help With Amp Install Please - Road Glide Forums
post #1 of 6 (permalink) Old 03-26-2013, 08:47 AM Thread Starter
mhud3780's Avatar
Hi guys. I don't have a service manual for my 2013 yet and I'm installing a new J&M 4channei amp and speakers this weekend. Looks like the fairing comes off the same as my 08 but I'm not sure about the gas tank. What are the steps for removing the tank?
Also, is adding foam as a sound deadner important? If so where do you get it? I don't want to do anything to create more heat.
2013 RGU after trading 2008 RGU with 72k. I love these bikes. "Life is highway made to be enjoyed on two wheels."
mhud3780 is offline
post #2 of 6 (permalink) Old 03-26-2013, 09:07 AM
Shrug's Avatar
Send a message via Yahoo to Shrug
Why remove the tank? You should be ale to slide cables front to rear without removing it. You might remove the front bolt so you can raise it up a bit. I 've run all sorts of wires stem to stern without removing the tank.
Dampening material inside the fairing will make a noticeable difference in bass response sitting still, but I doubt you'll notice any improvement at speed.
Dynaxorb works well.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #3 of 6 (permalink) Old 03-26-2013, 09:08 AM
RhinoHD's Avatar
Here you go Bud. this link will walk you through it. Its easy..
http://www.ironacesspeedshop.com/pro...tall-Guide.pdf
Life is good but it's not easy!
RhinoHD is offline
post #4 of 6 (permalink) Old 03-26-2013, 09:44 AM
JMJOHN
JMJOHN's Avatar
mhud ,,,,,,,,
not everything on this video will be applicable to your bike, but most of it should help, especially with the fuel tank removal, which I strongly recommend ,,,, http://www.youtube.com/watch?v=nEhfxdGhuB0 ,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 6 (permalink) Old 03-27-2013, 09:39 AM Thread Starter
mhud3780's Avatar
Thanks guys!
mhud3780 is offline
post #6 of 6 (permalink) Old 03-27-2013, 05:37 PM
thedude's Avatar
The plus of taking the tank off is you can run the wires into the plastic channel that holds all the other wires. Not a huge differance but after I found out how easy it is to take the tank on and off I prefer doing it that way.
thedude is offline
Help Please - Install Biketronics/Hertz Mille Legend ND17FLTRXS Audio 10 06-14-2018 04:49 AM
Tour Pack install instructions help please HogPro *General Road Glide Discussions/Pictures 5 01-01-2014 08:57 AM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
Help with clutch cable install please SKULLZ Controls & Handlebars 8 03-01-2012 10:27 AM
Ignition install please help!! raven006 Do-IT-Yourself 4 03-15-2010 02:47 PM
