Was your outer fairing a snug fit after upgrade? - Road Glide Forums
post #1 of 8 (permalink) Old 03-26-2013, 08:30 PM Thread Starter
adam_twenty6's Avatar
Just got the zx's, rf's and pbr300x2 in the fairing. now the outer is being "difficult". Anyone else experience this? I think it will go, but damn...
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #2 of 8 (permalink) Old 03-26-2013, 08:36 PM
Mike U's Avatar
I have the HW 6 pack with the ZX speakers and they are real close to the outer fairing.
It was a real PIA getting it back on.
Now that I've had to do it two more times it's seems easier.
Mike U
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 8 (permalink) Old 03-26-2013, 08:42 PM
h-donut's Avatar
once it's on the front hooks, check the gap between the windshield and the upper part of the inner fairing
there should be no gap prior to pressing the fairing back up and down onto the hooks
the three upper side tabs go over under under, you can also do them all under
factory look is over under under
the other thing's I've seem make them not fit, on mine are, sound deadening near the corners of the glove boxes is a no go
too much amp in between the glove boxes
or if the amp it self is bulging on a bracket that's slightly off
the front will protrude and cause an under gap
what exactly is it doing? or where do you notice it?
how did you mount the amp?
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 8 (permalink) Old 03-26-2013, 10:15 PM Thread Starter
Bent a piece of 18 ga sheet metal to mount amp. Copied your break angle. Not.hitting. sides don't want to line up easy as before. Magnet on zx's has a little rub spot from trying to get.it lined up. All the spacers on zx's making things snug?
post #5 of 8 (permalink) Old 03-26-2013, 10:22 PM
h-donut's Avatar
I have the ZX
are you trying with or without the headlights in the bezel already? sorry have to ask
I'd guess the top side tabs, if they're all on top, the fairing gets weirded out.
where is you biggest gap or bad fitment line? that'll give us a good idea
h-donut is offline
post #6 of 8 (permalink) Old 03-27-2013, 06:43 AM Thread Starter
Headlights out. Amp starboard side. Seems like weight of zx's might be making inner a little distorted. this will be an exercise in patients.
post #7 of 8 (permalink) Old 04-03-2013, 08:49 PM Thread Starter
I have taken the fairing off a couple times since the stereo upgrade was completed and it is easier to fit each time. The ZX's do hit just a bit, but if the longer it is on, the easier the next off-on is.
post #8 of 8 (permalink) Old 04-03-2013, 09:17 PM
I had the same problem the other day when I changed my inner fairing amps and speakers, then when I thought about it, the same thing happened when I first bought my bike. I believe with the parts being plastic and somewhat flexible when you make changes some things have to form back up to each other....if that makes sense, but that's just IMO.
Wanted Outer Fairing (possibly inner fairing as well) dimitri89 Wanted! (Buy or Trade) 4 02-19-2016 09:12 PM
OUTER FAIRING and INNER FAIRING Big Daddy Recon Parts for Sale 13 08-24-2014 10:42 AM
Too much treble after audio upgrade Turbo00 Audio 11 02-27-2014 10:40 PM
Outer Fairing Support Hooks & Fairing Damage ironmark *General Road Glide Discussions/Pictures 4 03-22-2013 10:39 PM
Outer fairing fit and warranty question??? bad86ta *General Road Glide Discussions/Pictures 13 03-03-2012 11:38 AM
