Hertz HCX165 instal into 2017 Road Glide Fairing - Road Glide Forums
 2Likes
  • 1 Post By Bunker
  • 1 Post By DE-Glide
post #1 of 3 (permalink) Old 07-10-2017, 09:31 AM Thread Starter
I am sure that this has been covered, but I cannot find any real consistent information or solutions for this. I am going to be installing some hertz hcx165 speakers in the fairing of my 17 RGS. I have read several posts discussing the fit situation... and that they are probably not going to fit without some sort of modification. I have read that people used heat guns and also that there are adapters for the speaker pods??
So, Here is what I would like to know..
1 - I would like to know what you did with a heat gun to remold the pod? are there any pictures of this?? I have a heat gun and would be up to doing this perhaps.
2 - speaker adapters? What model adapter and where did you get it? Will I still be able to use the oem speaker covers?
3 - What other solution is out there?
Thanks in advance..
dar1271 is offline
post #2 of 3 (permalink) Old 07-10-2017, 09:38 AM
Thanks in advance..
You should be fine with the HCX's, molding the pods was for the SV's which have a significantly larger magnet.
Biketronics has aluminum "adapters/spacers" that are about 1/4" and angle the speaker more to the driver and give a little bit more room for larger speakers.
dar1271 likes this.
Bunker is offline
post #3 of 3 (permalink) Old 07-10-2017, 01:58 PM
DE-Glide's Avatar
I've installed them into my 2015. I had to cut an opening to clear the magnet. I then used sheet plastic that can be heat formed to seal the opening, followed by a layer of dynamat for good measure. You will also have install the speaker upside down (logo at the top upside down) for the speaker leads to clear. You will also have to rotate the tweeter to fit under the factory grill.
Sheet plastic: https://www.amazon.com/KYDEX-Sheet-0...E2%80%9D+8PACK
sloride likes this.
Ride More, Work Less
DE-Glide is offline
Hertz HCX165 Speakers in 2015 RGS FITS!!! 12fltrx Audio 3 09-16-2015 10:06 AM
Hertz HCX165, which speaker rings? 2whlr4life Audio 11 04-25-2013 09:29 AM
Hertz hcx165 speakers from Phat Performance HDFFR Audio 6 03-19-2013 07:56 PM
xm radio instal flper67 Do-IT-Yourself 5 10-08-2012 08:56 AM
