Tuning Arc 600.4 for KRC 165's and HAT 6x9's??? - Road Glide Forums
post #1 of 6 (permalink) Old 07-12-2017, 01:31 AM Thread Starter
2016 RGS- stock radio with Arc 600.4 amp running pair of KRC's in fairing and HAT Imagine 6x9's in lids. Have gains set in same position for front and rear speakers but not sure what frequency to set amp for these speakers? Any input? Does lower freq= distortion?
scottrgs is offline
post #2 of 6 (permalink) Old 07-12-2017, 06:54 AM
you using a Line Leveler? If so the amp needs to be on Full/All Pass
If you're trying to use the 2 amp 8 speaker flash then you'll want the KRC's on Full/All Pass (they have their own xover) and the HAT's about 80 on the HPF (could go as high as 100 though, listen to it and see what sounds good to you)
Depending on who did your flash... some installers have tools to flash the old flash that worked that the dealers won't/can't do anymore.
Bunker is offline
post #3 of 6 (permalink) Old 07-12-2017, 09:52 AM Thread Starter
No line levelers- no flash. MPAK 12 has wire harness that reduces bass boost signal . Does more bass = distortion?
Was thinking somewhere arouns 100amp freq for KRC's and 90 for HAT's???
scottrgs is offline
post #4 of 6 (permalink) Old 07-12-2017, 12:25 PM
Spazz's Avatar
Call Karl at No Cage Audio ( sponsor here) he sells the MPAK systems and will give you guidance on setup.. he's a great guy and great to deal with
Sent from my SM-G955U using Tapatalk
RENO BAGGER AUDIO
Spazz is offline
post #5 of 6 (permalink) Old 07-12-2017, 08:34 PM
Khaotic's Avatar
My settings AA 600.4 6.5 Moto's and HAT 6x9s tuned.
Sent from my XT1650 using Tapatalk
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #6 of 6 (permalink) Old 07-22-2017, 01:12 PM
thereal142's Avatar
Wow, that is a ton of gain with the stock HU. Mine won't take anywhere near that much gain with 602's and HAT Imagine 6.5's....Which channels are the 602's on? These are my settings with the 602's on channels 1-2 and the stock HU at 15 of 18 volume. (Known max non-clipping volume on BoomBox.)
2017 FLTRXS Laguna Orange, Stage 2 Torque cam, SE Ventilator A/C, V&H Hi-Output Slip-Ons, Tour-Pak, Freedom Shields 12" Touring
thereal142 is offline
Which Focals- KRC 165 or EC 165 for RGS? scott16rgs Audio 4 07-04-2018 05:21 PM
FS Focal KRC and 600 watt Arc Audio amp. HarleyguyKC Miscellaneous for Sale 0 02-06-2018 02:17 AM
Arc 602 Speakers & 600.4 Arc Amp- anyone running bridged? scottrgs Audio 5 03-22-2017 07:06 AM
Focal 165 KRC Speakers Bunker Parts for Sale 1 08-16-2016 04:44 PM
Focal 165 KRC.......Amp Question Hayabusa1967 Audio 6 02-13-2015 10:30 AM
