Audio Options - Road Glide Forums
post #1 of 5 (permalink) Old 07-18-2017, 06:37 AM Thread Starter
Khaotic's Avatar
Audio Options
Is there a bluetooth solution or other that will allow me to hear my boom infotainment in my helmet while my wife hears on board speakers? She refuses to wear a full face. I just bought a new shark helmet.
Sent from my XT1650 using Tapatalk
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #2 of 5 (permalink) Old 07-18-2017, 09:40 AM
If there is such a solution it is a mystery to me. I tried every trick I could think of to get a Sena AND the fairing speakers to play the same music at the same time. No luck.
macabra11 is offline
post #3 of 5 (permalink) Old 07-18-2017, 11:52 AM
SteadyEddie's Avatar
Hmmmm, I have never tried this but wondering if it would work if you use your Phone to play your Music.
1. Plug the Phone into the USB Port via your charging cable to play the music via the Infotainment system
2. Bluetooth your Helmet to your Phone
Not sure of the phone is smart enough to handle it but it may play through your speakers via the hard cable and then through your helmet via the Bluetooth
SteadyEddie is offline
post #4 of 5 (permalink) Old 07-18-2017, 12:26 PM
Nope. Doesn't work. My phone (iPhone 7) would not let me both stream bluetooth and play through a connected source. Harley needs to just put in the tech to OUTPUT bluetooth as well as receive it.
post #5 of 5 (permalink) Old 07-18-2017, 03:57 PM
Well,.... Crud
2018 Road Glide Special Audio options Heavy Metal Audio 7 10-16-2017 04:58 PM
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Audio Options Orange09Glide Audio 19 02-19-2013 01:57 PM
Audio Options Help RhinoHD Audio 6 01-29-2013 08:29 AM
