plug and play radio - Road Glide Forums
  • 1 Post By ironmark
post #1 of 4 (permalink) Old 07-22-2017, 06:54 PM Thread Starter
plug and play radio
i just installed a aquatic av radio on my 2008 road glide radio works fine but now my brake lights and turn signals don't work??could i have blown a fuse? it is plug and play made for harley :
Renegade145! is offline
post #2 of 4 (permalink) Old 07-23-2017, 09:47 AM
Yes check the fuse. If the turn signals and brake lights worked before you did the work and they don't work now then you should go over your work and check everything you can, just installing the head unit should not affect the lights.
Renegade145! likes this.
post #3 of 4 (permalink) Old 07-23-2017, 04:58 PM Thread Starter
i have led lights on the front only could going from the stock radio to the new one be messing with the front lights or the hand controls
i checked my work can't see anything unpluged
post #4 of 4 (permalink) Old 07-24-2017, 09:38 AM Thread Starter
Thanks for your helps found the problems i pinched a turn signal wire and blown a fuse all set now
new plug and play radio 1stglide *General Road Glide Discussions/Pictures 17 03-01-2014 08:47 PM
Plug and play...?????? outcast1 *General Road Glide Discussions/Pictures 15 06-18-2012 10:46 PM
Is there a plug and play helmet setup? upstater Helmets 2 11-12-2011 12:25 AM
fltrx led plug and play resistor? swaite Lighting 2 09-25-2011 10:49 AM
Just ordered - Supposed Plug and Play HID Bi-Xenon Kit Timinfla2 Lighting 36 05-23-2011 06:40 PM
