Noobie with audio - Road Glide Forums
 3Likes
  • 1 Post By macabra11
  • 2 Post By Bunker
post #1 of 6 (permalink) Old 07-28-2017, 12:10 PM Thread Starter
Noobie with audio
So I bought a Klock Werks Kicker kit for my '17 RGS along with a BT line leveler. Once I started plugging it all up I noticed there wasn't a place to plug in the RCA part of the leveler since everything was plug and play... So i just hooked it up as is and figured I get Harley or someone else to flash it. I went to Harley the other day and they said they wouldn't be able to flash because about 6 months ago Harley made it to where no one could go in flash the infotainment unit not even an independent shop. Couple of questions.
Is this true?
If so, should I try and locate the wires and splice in the line leveler or is there another way around it?
2017 RGS Vivid Black
Matthew04833 is offline
post #2 of 6 (permalink) Old 07-28-2017, 01:34 PM
That sounds like a giant pile of BS if you ask me. I've heard of a number of people that recently had their radios flashed at their HD dealers. Do you have any other dealers around? Even if it isn't close by, call and ask another dealer about it and I bet you they can do the flash.
Matthew04833 likes this.
macabra11 is offline
post #3 of 6 (permalink) Old 07-28-2017, 02:37 PM
beatlesfab4fan's Avatar
Not for nothing but it sounds like, *cough* BULLSHIT *cough* to me.
As the other poster said, try another dealer, it sounds like the one you went to does not want to "take a chance" on screwing something up after you didnt put the "Boom!" crap in.
Mike
beatlesfab4fan is offline
post #4 of 6 (permalink) Old 07-28-2017, 04:34 PM
mastergunnera8's Avatar
Does your line leveler have plugs or wire ends?
mastergunnera8 is offline
post #5 of 6 (permalink) Old 07-28-2017, 05:54 PM Thread Starter
I was thinking it was bullshit after reading up on a bunch of post... But I hadn't read anything on the answer they gave me... Guess I'll follow the advice and call a few other dealers... they're are plenty here in the DFW area.
It has plugs.
post #6 of 6 (permalink) Old 07-29-2017, 07:11 AM
Each dealer can, but may choose to NOT flash your bike if you have aftermarket equipment.
Independent shops now have the ability to flash but I'd advise only using a shop that knows what they are doing.
options...
Call another dealer and have them flash the bike (0 amp 4 speakers) this will open the rear channel (a RG/RGS/SG/SGS don't come with the rear channels unlocked but only necessary if your amp can't split the signal or you just have to have fader). I've tried the 2 amp 8 speaker flash and I prefer the LL with the 0 amp 4 speaker flash.
Hooking up the LL isn't that difficult, it plugs into the harness from the radio, you can cut the ends off the RCA and plug it into the LL and then wire the high level going into your Kicker amp. I'm sure if you don't feel confident doing it, go by a local audio installer and tell them you want an RCA to high level harness made. Same thing, will have RCA ends to plug into the LL and then high level (speaker wire) ends.
Is this true?
Bunker is offline
RG Stereo Noobie Sweetdeal Audio 0 06-27-2018 07:35 AM
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Noobie Help 15 RGS Bar Swap shagyluke Controls & Handlebars 11 12-26-2014 06:52 PM
Another Noobie! iceberg67 New Members Welcome Area 50 08-17-2013 02:54 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
