Nav! Shut up! - Road Glide Forums
 7Likes
post #1 of 14 (permalink) Old 08-14-2017, 09:03 PM Thread Starter
Oldbie's Avatar
Nav! Shut up!
So I entered a trip, completed it, and she keeps giving me directions! "Recalculating, make a U-turn...."
rdeeming likes this.
It is difficult to free fools from the chains they revere.
Oldbie is offline
post #2 of 14 (permalink) Old 08-14-2017, 10:12 PM
twowheeladdict's Avatar
Using the joystick while on the map screen go to the right until you get to the menu icon. Click on it and you should see a menu item that says "Stop".
Oldbie and BigMike61 like this.
twowheeladdict is offline
post #3 of 14 (permalink) Old 08-14-2017, 11:58 PM
PSUUUUU's Avatar
I had to disable that annoying voice... constantly interrupting my tunes. Smh.
Oldbie likes this.
PSUUUUU is online now
post #4 of 14 (permalink) Old 08-15-2017, 08:11 AM
SteadyEddie's Avatar
This
SteadyEddie is offline
post #5 of 14 (permalink) Old 08-15-2017, 08:12 AM
That voice has saved my ass a few times........as well as sent me to a road that no longer was.........gotta take the good with the bad I guess
post #6 of 14 (permalink) Old 08-15-2017, 10:01 AM
flhtcm's Avatar
Change the volume on the feedback settings...
Sent from my SM-G935V using Tapatalk
flhtcm is offline
post #7 of 14 (permalink) Old 08-15-2017, 10:34 AM
canderso1970's Avatar
I won't chime in on my thoughts of the NAV capabilities because I am not a fan. However, I do have a couple of questions that may make my use of the NAV a little more tolerable:
1) Can you turn off the voice prompts so that you don't have the break in music when directions are being given?
2) Is there anyway to display a clock or an ETA for the destination?
3) Is there a way to display and use the NAV without playing a music source? I feel like the music is on by default and I have to mute the music source just to have the NAV on display?
I probably should read the manual.
-c
2016 Road Glide Special - Velocity Red
1976 Ironhead Hardtail Bobber - Citron Mist Metallic, Hand built by me
canderso1970 is offline
post #8 of 14 (permalink) Old 08-15-2017, 10:37 AM
BobRG15's Avatar
Lower your volume thru the feedback settings as flhtcm suggested and you will no longer hear the annoying voice and your radio volume will not be affected
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
BobRG15 is offline
post #9 of 14 (permalink) Old 08-19-2017, 07:15 AM
On mine I was having a similar problem; as soon as I got to my destination it started giving me more directions. Turns out there is a setting to calculate a round trip. Somehow (I don't know how) I managed to turn that function on. So as soon as I got to where I was going, it started to send me back to where I started from. I turned that option off in the settings and haven't had the problem since.
Oldbie likes this.
CantRider is offline
post #10 of 14 (permalink) Old 08-19-2017, 07:28 AM
-c
With the map displayed (not during a trip) there are two selections in the bottom corners of the display. If you navigate to these, you can change what is displayed there, using the joy stick. I usually keep my lefthand one showing speed and the right hand one showing the clock.
With the map displayed during the trip, I only have the righthand one available to change. You can select ETA, Miles to Destination, etc. I think there are 8 different selections to choose from.
-c
That's what I finally had to do. When all else fails; RTFM.
Ohiobellboy and Oldbie like this.
2007 Cylinder shut down Devilhog *General Road Glide Discussions/Pictures 13 07-02-2011 08:26 AM
Electronic shut down on trip skipperfltr *General Road Glide Discussions/Pictures 16 06-16-2011 12:50 AM
2010 cylinder shut down BillyBob *General Road Glide Discussions/Pictures 45 07-07-2010 09:37 AM
