Biketronics BT1014 - Road Glide Forums
post #1 of 4 (permalink) Old 08-15-2017, 03:06 PM Thread Starter
Dice21's Avatar
Biketronics BT1014
Anybody used the BT1014 from Biketronics to put a single DIN radio in a Rushmore RG? The factory radio is junk, and the nav is next to useless. Even the oil pressure screen, which used to actually give the PSI, now just says oil low when the bike is off, and OK when it's running.
I'm sick of dealing with trying to actually get good sound without spending a sh*t ton of money, so I'm leaning toward this.
Just curious if anybody has any experience with it, or if I'm going to be a test case.
Thanks
Dice21 is offline
post #2 of 4 (permalink) Old 08-15-2017, 03:43 PM
Thanks
I ran a Sony MEX M100BT and also a Kenwood 998 with their kit. You'll definitely get better sound that's for sure.
I was running my phone for GPS (Waze) and it was pretty good but tbh, the 6.5 is just easier to deal with ESPECIALLY if you use USB and want to search through it.
The 6.5 is a pita but for me, it's still the best option as far as convenience goes even if it does route me down dirt roads
As far as sound, a good DSP will make it sound good will cost you less than the BT1014.
The BT1014 was a great option but now with DSP's and the Sony XAV AX100 (I'm sure more of this double DIN screen, single DIN chassis will be coming to market soon as well as this one's done) a $400 kit plus a single DIN head unit just isn't worth the cost imo.
Bunker is offline
post #3 of 4 (permalink) Old 08-15-2017, 03:49 PM Thread Starter
Dice21's Avatar
Any suggestions on a good DSP?
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #4 of 4 (permalink) Old 08-15-2017, 04:50 PM
JL FiX if you don't want to program much but - it's on the larger side
Arc PSM but has a very steep learning curve - tiny, about the size of a pack of smokes and full featured
Bunker is offline
Biketronics stereo splash cover for roadglide tntrash Miscellaneous for Sale 2 01-24-2012 12:57 PM
biketronics 180W per channel BT480 h-donut Audio 12 09-11-2011 06:54 AM
Biketronics BT1002 adapter sprint12 Classifieds Archive (3 months old+) 0 03-01-2011 04:53 AM
Biketronics Titan Amp hodgeaaco Aftermarket Accessories 2 08-17-2010 09:09 PM
Kudo's to Biketronics Neano62 *General Road Glide Discussions/Pictures 0 06-25-2010 10:42 PM
