Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? - Road Glide Forums
  • 1 Post By UT_Larry
post #1 of 5 (permalink) Old 09-06-2017, 12:47 AM Thread Starter
Adding Stretched bags to RGS but rear fender extension has no hole for antenna so think I will add a hidden antenna inside fairing. Will this hurt navigation signal or operation on my GPS or bluetooth on stock radio?
scottrgs is offline
post #2 of 5 (permalink) Old 09-06-2017, 02:28 AM
UT_Larry's Avatar
No. The rear antenna is fm/am/wb only. You can have diminished reception with the hidden. If you have an amp you most likely will have signal issues. One alternative is to rotate the mount and tuck the antenna underneath the fender, easier with a stubby antenna. There are some forum threads that give more details about how to do that.
beatlesfab4fan likes this.
UT_Larry is offline
post #3 of 5 (permalink) Old 09-06-2017, 06:27 AM
GRAYWOLFHD's Avatar
I did it on my SGS based on a video I found on Youtube. https://www.youtube.com/watch?v=ks7NoK0A1GA
On my RGS,I just removed it as I never listed to the FM on the radio.
2017 FLTRXS Velocity Red Sunglo
GRAYWOLFHD is offline
post #4 of 5 (permalink) Old 09-06-2017, 07:28 AM
Reception
I did the in the fairing one on mine and I have nothing to compare it to on my 15, but I can hear the motor and pipes just fine lol.
Drampy is offline
post #5 of 5 (permalink) Old 09-06-2017, 10:34 AM
I put mine under the fender/seat. The station's I use are strong enough. But the weak ones are gone.
Buzzy is offline
Antenna reception problems riverdave1 Audio 3 10-26-2016 08:38 PM
Radio Antenna and reception issue Southpaw Slim Audio 5 03-28-2016 07:42 PM
Antenna, go with a hidden or can I remove it? Mooseinthetub Audio 17 02-22-2016 03:55 PM
Remove Antenna Studs TourPak Gary R Do-IT-Yourself 1 04-05-2015 03:00 PM
How do you remove the radio antenna cable? NoChute Troubleshooting for Road Glides 11 05-28-2011 06:28 AM
