Charging System - Road Glide Forums
post #1 of 6 (permalink) Old 09-10-2017, 08:46 PM Thread Starter
Charging System
What is the maximum amperage draw in aftermarket audio that the stock charging system can support? Bike is 2015 Special.
lwshack is offline
post #2 of 6 (permalink) Old 09-11-2017, 08:17 AM
Not sure the actual number (maybe in the manual?)
I ran 2 amps (JL 280/4 and a Fosgate TM400) and a power supply for an MEX100 in my 15 RGS. I did change the battery out to a Stinger but never had any issues
Bunker is offline
post #3 of 6 (permalink) Old 09-11-2017, 05:40 PM Thread Starter
Thanks Bunker.
lwshack is offline
post #4 of 6 (permalink) Old 09-11-2017, 05:58 PM
Clutch1's Avatar
Find the output in wattage of your stock stator in your maintenance manual. Then subtract 200 watts for the engine and lights. Whatever is left over is what you can use for audio. Watts=Volts x Amps.
08 has a 540 watt charging system. Not sure they put bigger ones in the Rushmore bikes or not.
Clutch1 is offline
post #5 of 6 (permalink) Old 09-11-2017, 06:57 PM
bucketlisthd's Avatar
My 15 RGS doesn't even notice my 500 watt amp.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 6 (permalink) Old 09-12-2017, 10:22 AM
wevsspot's Avatar
Nope, mine either.
wevsspot is offline
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 08:25 AM
charging system issue crosen41 Troubleshooting for Road Glides 6 05-07-2013 01:03 PM
2002 FLTRI charging system test CraigB Troubleshooting for Road Glides 5 11-02-2012 11:18 PM
USB Charging Mount/System GRTSHRK Do-IT-Yourself 4 10-07-2012 06:52 AM
Electrical System Not Charging jimmyray11349 Troubleshooting for Road Glides 3 03-23-2012 07:31 AM
