Stereo cutting out - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 09-17-2017, 07:10 AM Thread Starter
steel breeze's Avatar
Stereo cutting out
I've got a Kenwood marine grade deck with the Biketronics Retro Radio adapter. When I hit a bump, my music stops playing. When I'm listening to stored music from my phone through the blue tooth, it switches over to the USB chip. When I leave it on the USB and hit a bump, sometimes it just stops altogether. That makes me think it's something to do with the deck. I've had the fairing off, and everything is snug and connected. Bike is an 05. Looking for ideas before I dump this deck and look for another one. Thanks.
Dave
2005 Shark. Madstad shield, Progressive Mono tubes, Kenwood KMR-M315 deck, Alpine SPR-60C speakers, Trask V-line bars, V&H Pro Pipe, S&S cams, 21" Fat Spoke, extended bags, SE air cleaner.
steel breeze is offline
post #2 of 12 (permalink) Old 09-17-2017, 07:43 AM
Dave
It could be the BT inerface also. Disconnect the BT inerface and see if it still does it.
Big_gary is online now
post #3 of 12 (permalink) Old 09-17-2017, 12:47 PM
calgaryglide's Avatar
The BT stereo adapter has a built in AVC, automatic volume control, Gazso19 has been going thru this same ordeal for a couple of months. Contact BT to find out how to turn off their AVC and this will most likely solve a bunch of problems.
Also message Gazso19 for the full story regarding his speakers/amps and the same problems that were plaguing him. Took his fairing off at least twice at SW to work on the issue. He can put a pre-Rushmore fairing on and off blind folded now!
Calgaryglide
calgaryglide is online now
post #4 of 12 (permalink) Old 09-17-2017, 03:32 PM Thread Starter
It could be the BT inerface also. Disconnect the BT inerface and see if it still does it.[/QUOTE]
I've ridden using just the USB with no Bluetooth enabled, and it still cuts out.
post #5 of 12 (permalink) Old 09-17-2017, 03:51 PM Thread Starter
Calgaryglide
It's cutting out even when not using the BT. When I'm using just the USB chip it still cuts out. I look at the screen, and it says "reading". It will say that for a minute, then resume playing. Or, it won't play at all, and says, "No music found". Weird...
post #6 of 12 (permalink) Old 09-17-2017, 06:56 PM
I've ridden using just the USB with no Bluetooth enabled, and it still cuts out.[/QUOTE]
You still need to actually unplug the inerface from the back of the HU.
steel breeze likes this.
post #7 of 12 (permalink) Old 09-18-2017, 08:25 PM Thread Starter
You still need to actually unplug the inerface from the back of the HU.[/QUOTE]
Okay. I'll try it tomorrow. Once I put it back together, I'll head down the road, and look for some bumps. Lol! If it works, what are my options if I want to use my Bluetooth for GPS and music through the HU?
post #8 of 12 (permalink) Old 09-19-2017, 10:17 AM
Okay. I'll try it tomorrow. Once I put it back together, I'll head down the road, and look for some bumps. Lol! If it works, what are my options if I want to use my Bluetooth for GPS and music through the HU?[/QUOTE]
Your Bluetooth will still work with or with out the BT hand control interface.
If you don't experience any problems once you unplug the interface, it's the BT inerface and/or hand switch causing problems.
post #9 of 12 (permalink) Old 09-20-2017, 12:23 PM Thread Starter
If you don't experience any problems once you unplug the interface, it's the BT inerface and/or hand switch causing problems.[/QUOTE]
Well, I found a loose wire and tightened that up. I didn't see any one wire specifically for the BT. Went for a ride, and it's still cutting out. Back to the drawing board...
post #10 of 12 (permalink) Old 09-20-2017, 12:26 PM Thread Starter
Here's the only harness that plugs into the hu.
Speaker cutting out JJSW1283 Audio 12 09-25-2014 09:41 PM
Speaker cutting out Rig Magician Audio 2 08-01-2013 09:20 PM
speakers cutting in and out sloride Audio 7 05-19-2013 03:11 PM
HD Head Unit cutting out watsondog Audio 14 04-20-2012 09:33 AM
Elf amp keep cutting out luvriding Audio 0 04-19-2012 09:00 PM
