j&m rokker 330 amp question - Road Glide Forums
post #1 of 6 (permalink) Old 09-17-2017, 09:59 AM Thread Starter
a couple months ago I bought a hogtunes amp and speaker kit. since install I lost all my radio stations. so I contacted them and they pretty much said I am beat. so now I am looking to replace it with either BOOM II or J&M. my question is if I replace it with the J&M am I goin g to loss my radio stations again? thanks
Sgt Goody is offline
post #2 of 6 (permalink) Old 09-17-2017, 09:09 PM
I have had no problems with mine. Still have radio stations
bbaskin is offline
post #3 of 6 (permalink) Old 09-19-2017, 10:23 AM
I had no problems with radio reception with my hog tunes system either. Seems a little odd that you did. Keep in mind, any class d amp (hog tunes, J&M, etc) will interfere with FM if you are running an internal hidden antenna. It's best to run the factory wiring and mast. If you have a special, you can take the bolt out of the bracket, rotate the bracket forward, drill a new hole for the bolt and have your mast pointed forward. At this point you can zip tie it along the rear fender struts and under the left side cover. If it's an ultra, you will need to buy the bracket, grommet and feeder cable from Harley for around $50 (look at the online microfiche to get your part numbers)
Jt_Hd is offline
post #4 of 6 (permalink) Old 09-19-2017, 12:10 PM Thread Starter
No internal ant. Never touched the ant and hogtunes is the company that installed it. So I guess I have a bigger puzzle to figure out
post #5 of 6 (permalink) Old 09-19-2017, 02:28 PM Thread Starter
Ok so I moved the ant. Just like ya said and still nothing.
post #6 of 6 (permalink) Old 09-19-2017, 02:29 PM Thread Starter
Oh and I also checked all the wiring from front to back and the ant cable. It is all good.
j&m rokker 330 question Sgt Goody J&M 22 10-15-2017 10:40 AM
JM Rokker series 2 330 amp kit with tweeters jmoura22 J&M 0 07-02-2016 07:59 PM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
Rokker XT -V- Rokker BigDave55 Audio 4 03-19-2013 04:59 PM
Tuning question - JM Rokker 7.25 + ELF 2125 amp modot66 Audio 0 02-21-2012 01:48 PM
