2018 audio upgrade - low budget option? - Road Glide Forums
 55Likes
post #1 of 150 (permalink) Old 10-03-2017, 11:08 PM Thread Starter
georgec's Avatar
My 2018 RGS is awesome, however, I cannot hear the stereo on the freeway. Is there an economical solution? Maybe just speakers? I don't want to change out the whole system, just an inexpensive (cheap) solution. Is this possible, or will I need to spend ridiculous amounts of cash?
Also, is there anything that Harley offers that is ok?
georgec is online now
post #2 of 150 (permalink) Old 10-04-2017, 12:00 AM
UT_Larry's Avatar
HD products are overpriced. You need more than speakers you also need an amp & miscellaneous parts. Biketronics makes a good plug & play kit. Under $800. They may still have a forum discount & the do have sales.
http://www.biketronics.com/2015-and-...eaker-package/
sloride likes this.
UT_Larry is offline
post #3 of 150 (permalink) Old 10-04-2017, 05:14 AM
Jlaudio hx 280 x4 biktronics titan II 6.5 coaxles biktronics line levler and a good Amp. Install kit from NVX Audio and you will enjoy
Music once again!!!!!!! For small $ good luck
dozer23 is offline
post #4 of 150 (permalink) Old 10-04-2017, 05:59 AM
beatlesfab4fan's Avatar
I'm not sure what inexpensive is for you, but the easiest and cheapest way to get much better sound without breaking the bank is a two step process.
1. Get a new windshield. The cheapest quality option out there IMO is the LongRideShield. longrideshields.com/collections/2015 I'm currently running the Thresher as the weather has started to cool off and it keeps a little more wind from getting into the cockpit area. All summer I ran the Stingray because it let a little more air into the cockpit area. (yes I have both of them, I got them when they first came out and got them for less than 80 bucks a piece. They are a bit more expensive now but still a really good deal. Follow the directions for ordering the right height and you should be fine or call them up they are really nice people to deal with) If you wait a week or two you may be able to get them for a little better price with Columbus day coming up.
2. There are a number of good quality amps to be had for pretty cheap money that work really well in the Shark. Cerwin Vega has the B52 and the B54. Soundstream has the Picasso Nano series. There are a few others that are good quality that wont break the bank but do yourself a favor and stay away from the Boom! stuff. Its way overpriced IMO and not worth it.
The best bang for the buck IMO speaker wise is the Infinity Kappa 6211i. Its a 6.5" coaxial that sounds good, is a ~2ohm speaker and can usually be had on Amazon for a touch over a hundred bucks. Can you buy cheaper or more expensive speakers? YUP but dollar for dollar the Kappas are a great investment when on a budget.
The only other things you will need are a Biketronics BT355 line leveler BT355 HD Radio Line Leveler And Pre-Amp Adapter for 2014 and Up - Biketronics Inc and an amp install kit. I went to a local stereo shop and got the wire and fuseholder from them and spent less than 30 bucks.
Dont get it professionally installed, you can do this yourself and save money, plus you will get familiar with the Shark. If you take your time it will take you 1/2 a day. If you have had the fairing off and are familiar with the girl a little bit , it can be done in 4 hours or less.
There are a bunch of threads here on the amps and speakers and how to do the install. It really is a straight forward upgrade and you will be happy with the end result. Hopefully you dont end up like some people and get the stereo bug. (i say that like I'm immune from said bug as I toy with the idea of spending more money on new stuff for my stereo)
With a little shopping around this can be done for about 500 bucks, and will sound leaps and bounds better than what you have now.
Hope this helps,
Mike
beatlesfab4fan is offline
post #5 of 150 (permalink) Old 10-04-2017, 09:49 AM
wevsspot's Avatar
Hope this helps,
Mike
This is an excellent recommendation for a very good sounding low budget setup. I didn't have a lot of cash to spend on my upgrade and I was an early adopter so there weren't a lot of options at the time.
At first I started with just speakers - JBL GTO638
I ran that way for about a month
Then I added the Cerwin Vega B2
Much happier
In early 2016 I swapped out the GTO638 speakers for the Kappas and also bought a portable Oscilloscope to help me tune.
Currently running
Cerwin Vega B2 (predecessor to the B52 / B54)
Infinity Kappa 62.11I
BT355 Line Leveler
There weren't any installation kits available when I did mine so everything went in the old fashioned way, wire, splice, solder etc.
All in you can do the above system for less than $400.
Is it audiophile quality? No
Is it the best you can buy / build? No
Will it win any bike night noise awards? No
Can I hear it loud and clear running down the interstate at 80+ MPH? Yes
And my wife can hear the tunes from the back of the bike as well.
wevsspot is offline
post #6 of 150 (permalink) Old 10-04-2017, 10:43 AM
bucketlisthd's Avatar
A speaker change alone won't get you there. You also need an amp. Been there. Done that.
bigal51 and beatlesfab4fan like this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #7 of 150 (permalink) Old 10-04-2017, 03:23 PM
I guess I should have made that clear in the first post.
You can put a thousand dollar pair of speakers and it will still sound like shit due to the fact that the head unit only puts out 25 watts/ channel.
You MUST add an amp if you are looking for even mediocre sound. The kappas like power and the B2/B52/B54 do nicely on a budget.
You also need a line leveler and the BT355 is a good one that takes a lot of the nasty signal away. If you mention RG.org they still give a discount I believe.
Mike
post #8 of 150 (permalink) Old 12-25-2017, 11:11 PM Thread Starter
georgec's Avatar
I heard these were good....
ARC AUDIO MOTO 600.4 and Focal ES 165KX2 speakers. Comments, anyone run this setup?
post #9 of 150 (permalink) Old 01-21-2018, 04:22 PM
PlanoAttorney's Avatar
+ 1 for this question. Went to a local shop today to discuss, they had a StreetGlide in the bay and said thy have done several Harley installs (must have all been SGs because i had to point out, my fairing does not look like that one and the installer seemed a little surprised).
This particular shop highly recommended the Focal speakers (did not write down the model) and a Focal 4 channel 480Watt Amp. This apparently fits under the SG hood, anyone tried to get it into a RG?
I came home and started looking for some Focal specs and realized amps are Class A, Class B, etc. Anyone able to tell me which class to look for or if that even matters?
PlanoAttorney is offline
post #10 of 150 (permalink) Old 01-21-2018, 05:26 PM
That Cerwin Vega B52 is key to a low $ system @ $130 from amazon. I also like the value of the Hertz HCX 65 for $160. I tried the Kappa's in my bike, but the grill clip hit the speaker and would have torn it up, I'm sure.
If You have an indie shop that has the capability to flash the radio cheap enough... You can avoid buying the line leveler too...
V-man is offline
Budget Friendly Stereo Upgrade for Batwing WestTexasRanger Sold 2 05-19-2016 07:46 AM
Upgrade on a budget? Ptl203 Audio 2 12-12-2015 01:50 PM
1999 Road Glide Sound Upgrade (on a budget!) Roadog Audio 12 03-23-2013 10:38 PM
Budget?? We don't need no stinking budget! pacfan1967 General Off-Topic Discussions 3 01-09-2013 05:32 AM
