My take on HD Hidden antenna - Road Glide Forums
post #1 of 5 (permalink) Old 11-06-2017, 03:41 PM Thread Starter
I wanted the clean look of no whip antenna or even a stubby. I do not listen to the radio very often(I use my flash drive), but wanted that option.
I live in Florida, so nothing to impede a radio signal and it depends how good of a radio station one has, other areas will be different. I installed the antenna unit per HDs instructions and routed the antenna leads around the speaker pods, per HD. I headed out to check how far the Hidden antenna would work. I found that I lost the radio signal about 1/2 mile before I would normally loose the signal with the whip antenna. That works well enough for me, also I do not have any amp outside what comes with the stock radio.
FLTRXS18 is offline
post #2 of 5 (permalink) Old 11-06-2017, 05:20 PM
Smoke338's Avatar
I have the hidden antenna also... My bike had that option when I bought it, so I cant compare before/after. I do notice just a bit better reception from my truck stereo driving/riding the same route to and from work. but that should be expected since the truck antenna is much higher than the bike antenna.
I like the clean (no antenna) look of the hidden antenna system. I've got a pile of music on my phone if the radios not playing anything worth a damn, or the reception is lacking ............
Smoke338 is offline
post #3 of 5 (permalink) Old 11-08-2017, 10:41 AM
vring's Avatar
Pandora seems to solve ANY reception issues! I still have the stock antenna but an interesting thought. I have an '18 RGS and the message "Media not Recognized" began appearing a few weeks ago. Told by the dealership it was the latest IOS load from Apple that was the cause. Anyone else experience that?
USMC 1982 - 2004
"There are only two kinds of people that understand Marines: Marines and the enemy. Everyone else has a second-hand opinion."
~Gen. William Thornson, U.S. Army~
vring is offline
post #4 of 5 (permalink) Old 11-08-2017, 10:53 AM
VikingRider's Avatar
I use the antenna-whip flying the colors!
FLTRSEI2
VikingRider is offline
post #5 of 5 (permalink) Old 11-08-2017, 03:01 PM
08Zinc's Avatar
Just to add, the stock antenna on the FLTRXS was not nearly as good as on my FLTRU. Switching from the stock to the hidden on the FLTRXS I found about the same as you, slight loss, but not enough to complain about. None of the bikes have matched my cages, which are not equal either.
Blessings, Zinc -
08Zinc is offline
Hidden Antenna? Wes10RG Aftermarket Accessories 11 10-25-2017 10:00 AM
HD Hidden Antenna Install Rushmore/Question FLTRXS18 Do-IT-Yourself 2 10-24-2017 06:34 PM
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 10:34 AM
Anyone use the HD Hidden AM/FM/WB Antenna?? ironmark Audio 10 01-23-2012 02:07 PM
2010 King Tour Pack with hidden antenna in Fairing DED HD Aftermarket Accessories 0 07-26-2010 01:34 PM
