Questions on paralleling amp - Road Glide Forums
post #1 of 9 (permalink) Old 11-26-2017, 04:50 PM Thread Starter
Heavy Metal's Avatar
As you see in the pic at 2ohms 250 Watts
So instead of 2 speakers I Now have 2 pairs of 4ohms speakers, now paralled will make 2ohms and each speaker would get 125watts if Iím correct? Right?
File Type: jpeg 7C862AE9-4463-4285-B41E-051A37A99F64_1511736402318.jpeg (20.1 KB, 54 views)
Heavy Metal is offline
post #2 of 9 (permalink) Old 11-26-2017, 06:44 PM
You got the ohms correct, but each channel will push 125/2 or 62.5 w/ speaker.
post #3 of 9 (permalink) Old 11-26-2017, 06:56 PM Thread Starter
Gotcha, thanks
post #4 of 9 (permalink) Old 11-26-2017, 07:03 PM Thread Starter
How about if bridging them from 2 speakers to 4 speakers whatís the wattage per speaker then?
post #5 of 9 (permalink) Old 11-26-2017, 07:24 PM
I thought you were talking about running 4 speakers. You bridge the channels, not the speakers. A 2 channel amp can bridge down to 1 channel increasing the out-put wattage.
post #6 of 9 (permalink) Old 11-26-2017, 07:42 PM Thread Starter
Ok thatís what I thought, Iím wanting to figure out how to get @125 Watts 4 speakers 4 ohms without a lot of amp comsuption.
post #7 of 9 (permalink) Old 11-26-2017, 07:54 PM
With that amp alone, you can't.
post #8 of 9 (permalink) Old 11-26-2017, 08:32 PM
mpholland's Avatar
If you series two pairs, you would then have two 8 ohm pairs. If you then parallel the two pairs you would have a 4 ohm load between all four speakers. Bridge the amp mono and you would have 125 watts per speaker. Unfortunately, you would only have one channel, but it would solve your math problem.
Rest in Peace Michael Wade
mpholland is offline
post #9 of 9 (permalink) Old 12-04-2017, 04:01 AM Thread Starter
So it would now take 2 amps to get 2 channel. Hmm
Paralleling speakers 4 ohm 2 ohm using amp set up to parrallel Heavy Metal Audio 16 01-06-2018 06:09 PM
DETAILS - PA & MD (& VA & ??) Meet & Greet 2017 08Zinc Organize Rides Here 28 05-10-2017 01:50 PM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
Interesting Read & Questions? TearlessTom ECM/Fuel Management systems 4 04-08-2012 10:41 AM
questions about V&H fuel pak BklynRGU ECM/Fuel Management systems 3 01-01-2012 09:16 PM
