Tweeter and Woofer no crossover - Road Glide Forums
post #1 of 5 (permalink) Old 01-06-2018, 11:50 AM Thread Starter
Heavy Metal's Avatar
How does one connect both together as one without changing impedance? 4 ohm woofer and 4 ohm tweeter without using a crossover? Yet set the frequency up correctly to separate the two and sound good on all ends?
Heavy Metal is offline
post #2 of 5 (permalink) Old 01-06-2018, 01:24 PM
mpholland's Avatar
You don't. Connecting them in parallel will halve your impedance and full frequency to a tweeter will blow it in a few watts. You must have some sort of crossover, even if you run full range to the woofer and just a simple resistor/cap network to the tweeter.
Rest in Peace Michael Wade
mpholland is offline
post #3 of 5 (permalink) Old 01-06-2018, 05:03 PM Thread Starter
So as you stated a simple resistor/cap network to the tweeter, attached to the woofer to tweeter and from there the woofer to amp. Any suggestions on resistor / cap size.
post #4 of 5 (permalink) Old 01-07-2018, 07:59 AM
Brewiz's Avatar
Why would you not use the crossovers matched to the woofer/tweeter combo that you plan to use?
Brewiz is offline
post #5 of 5 (permalink) Old 01-07-2018, 10:22 AM Thread Starter
Why do you need it really that to do a fixed line?
Tweeter/crossover install question rwb1967 Audio 2 05-16-2014 12:32 PM
Inner fairing speakers wired in series using crossover Biljac Audio 7 06-02-2013 10:59 PM
09 headpipe and crossover with heatshields MoRob Classifieds Archive (3 months old+) 0 07-24-2012 04:54 PM
Hog tunes woofer for lowers dthielenhaus Aftermarket Accessories 2 12-19-2011 07:41 AM
S&S crossover duals for 95-11 touring TobyJ Intake and Exhaust 3 11-28-2011 12:12 PM
