18 RGS fairing speaker install RF T1650s - Road Glide Forums
post #1 of 7 (permalink) Old 01-19-2018, 08:30 AM Thread Starter
bless0's Avatar
I am trying to use Rockford Fosgate T1650s component speaker setup. The 6.5 midrange speaker does not fit flush inside the fairing speaker cavity. The speaker magnet seems to be hitting the inside of the speaker box cavity. These speakers look a bit smaller than some of the other speakers like the infinity kappa 62.11 that a lot of folks here use. Are the speaker enclosures on the 18 RGS different than the 15 RGS. I think I had more room in my 15RGS.
bless0 is offline
post #2 of 7 (permalink) Old 01-19-2018, 02:03 PM
lastride's Avatar
Use a heat gun on the speaker pod to reshape it were the magnet hits. It shouldn't take much.
lastride is offline
post #3 of 7 (permalink) Old 01-19-2018, 03:23 PM Thread Starter
bless0's Avatar
Good Idea I will try that..Should I do it from inside the pod or heat it from the outside since the fairing is off?
bless0 is offline
post #4 of 7 (permalink) Old 01-19-2018, 04:33 PM
Are you using any type of adapter or mounting directly to the pods?
roadie13 is offline
post #5 of 7 (permalink) Old 01-19-2018, 09:20 PM Thread Starter
bless0's Avatar
I am trying to go directly into the PODS.. I used JBL GTO638 6.5inch speakers in my 15 RGS and they went directly into the pods with no issue. These RF 6.5 mid range speakers from the T1650s component
system are hitting the inside of the pods and not allowing a flush fit onto the pod speaker ring.
bless0 is offline
post #6 of 7 (permalink) Old 01-22-2018, 09:02 AM
lastride's Avatar
I heated them from the outside of the pod.
lastride is offline
post #7 of 7 (permalink) Old 01-26-2018, 09:15 AM
joeyzaza's Avatar
I installed 6.5" HERTZ speakers in my 2016 FLTRXS and had the same problem. I ended cutting the housing of the speakers just enough to fit the magnets. I used the original mounting. It work perfect.
joeyzaza is offline
Stock speaker lids - RF did it again!! Blue Dragon Audio 22 08-22-2017 08:06 PM
RF Speaker Swap, micro sub question Jwasielczyk Audio 9 01-12-2016 07:17 PM
Hawg-Wired 6-Pack + RF 165 Inner Fairing Install - with Pix Slider57 Audio 8 04-20-2014 01:09 PM
Fork Cover hitting inner fairing RF speaker adam_twenty6 Audio 9 04-03-2013 06:51 AM
RF PBR300x4 amp and RF speakers? GLYDDN11 Audio 2 02-02-2012 09:46 PM
