Comm not working - Road Glide Forums
post #1 of 5 (permalink) Old 01-19-2018, 08:37 PM Thread Starter
Comm not working
I have a 2012 RoadGlide ultra. Recently I'm unable to use my comm headset effectively. When I receive a phonecall I can hear just fine. I just can't speak and be heard. Same thing happens when just trying to use the intercomm. I can hear in my helmet, but my voice can't be heard from my passenger.
Anyone know what this could be?
pryda is offline
post #2 of 5 (permalink) Old 01-20-2018, 06:51 AM
JacktheBagger's Avatar
My 11 Ultra I had to get the HD BOMM unit to use it , I could hear incoming calls but not xmit out . Spliced a couple wires in and was good to go . Never used the intercom so don't know if there is something different there going on .. This is pairing thru a Zumo Road Tech 550 ...
2011 Ultra
JacktheBagger is offline
post #3 of 5 (permalink) Old 01-20-2018, 07:36 AM Thread Starter
I have the BOMM and a Roadtech 660 GPS. This setup has worked flawlessly for the last 5 years. Not sure what happened.
pryda is offline
post #4 of 5 (permalink) Old 01-20-2018, 07:37 AM
Post
Assuming you have your Intercom settings correct or your using the PTT switch for intercom and you haven't changed those settings. If everything you just mentioned worked before and just stopped than I would suspect a bad helmet system or a bad helmet drop cord.
Have you tried using another known good helmet and cord?
If you have and the problem is still present than your going to have to trace a few wires from your helmet connection port to the radio. You will only be interested in the Mic - and Mic + wires. If they check out than your radio is suspect.
[email protected]
pilot is offline
post #5 of 5 (permalink) Old 01-22-2018, 07:17 AM
I didn't see your last post before I posted. Disregard my last post.
You have two Red wires coming out of the Bomm. Check to make sure they are both still connected.
If they still look to be connected and you don't see a problem with them send me an email I will give you further troubleshooting information.
[email protected]
pilot is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
Comm unit for the 13' CVO RG custom Rig Magician Audio 17 09-02-2013 05:51 PM
WTB - Comm system pieces 93-331-29psi Wanted! (Buy or Trade) 7 05-31-2013 07:15 AM
What Comm system do you use? Fire-Medic Helmets 15 12-06-2012 02:08 AM
Comm. System Scarecrow Helmets 1 09-05-2011 01:29 PM
