Speaker configuration with HD Amp - Road Glide Forums
post #1 of 4 (permalink) Old 01-20-2018, 06:53 AM Thread Starter
The bike is a 16 RGU, 4 speaker with HD boom amplifier. Installation and flash were made by the dealer.
I just got the Diag4bike diagnostic tool, so I decided to check the boombox setting and had a surprise.
Speaker configuration was settled to “no configuration” and Amp 1 & 2 we’re both settled to “off”
I checked the HD instructions and they state that the configuration in place should be selected with digital technician.
So I changed to the follows:
4 Speakers/2 front fairing/2 rear pods/1 Amp
AMP1 on
AMP2 off
Everything seems to sound good, EQ sound different and even at max volume no or very little distorsion depending by the song.
Now the question: does anybody know if that is the right configuration for my setting?
I know that J&M reccomends the speaker conf with “no amp” and amp 1&2 on “no”, so my concerns for the HD settings
Beaver is offline
post #2 of 4 (permalink) Old 01-22-2018, 02:38 PM Thread Starter
The old rule still apply: if it works don’t mess with it.....
Went on a ride yesterday with the new configuration, everything sounded great up to the last mile and then I Lost the rear intercom completely and I only have crackling sound in the front one. The bike speakers instead work really great.
Checked the system, no codes. I then reflash into the initial configuration and then I got two codes no listed on the electrical manual: C186 and C187.
Any idea on their meaning? As said the manual does not list them
Beaver is offline
post #3 of 4 (permalink) Old 01-23-2018, 03:31 PM Thread Starter
Run the radio diagnostic, got the codes
U0186 amp 2 “active”
U0187 amp 3 “active” ...... amp 3??????
B1360 front headset “historic”
B1364 rear headset “historic”
Did the reset and “B” codes went away, start thinking the radio is gone.... next Friday at dealer probably with a wide open wallet
Beaver is offline
post #4 of 4 (permalink) Old 01-26-2018, 09:13 AM Thread Starter
Went to the dealer.
I’ve been told they found 2 inverted wires in the headset line, they corrected the position and everything went fine. Compared to the past it seems headset volume and quality are now increased in performance.
I think they mismatched the connection when I had the boombox amplifier installed and they managed to have it working by the digital technician. When I applied the Diag4bike tool probably the coverage came exposed.
Anyhow, now everything works fine and better than before and no money was spent because they were the only one to touch the hardware in the past.
Case closed
Beaver is offline
Amp configuration Matt16RGS Audio 19 03-20-2017 10:06 AM
Opinion on configuration modot66 Engine Related 22 01-08-2014 01:48 PM
J&M Rokker Speaker & AMP Review BillyBob J&M 12 01-20-2013 01:51 PM
6"x9" speaker kit that fits HD speaker lids JuicedHD Audio 1 01-18-2013 06:19 PM
