B 54 speaker wire color code - Road Glide Forums
  • 1 Post By Harleywood
post #1 of 5 (permalink) Old 01-21-2018, 09:33 AM Thread Starter
bigal51's Avatar
I have my C V b-54 mounted and I need to know the + and - to each channel. Had calls into tech support all week but they don't answer phone and don't return calls. I have a purple/green and a slate/white with corresponding black stripes on each set. ALSO do you run the turn one mode to VOX? Thanks for any help.
2017 Road Glide Ultra -STOCK!!! (so far) Member: Ironbutt Association
bigal51 is offline
post #2 of 5 (permalink) Old 01-21-2018, 09:50 AM
Can't help You with the wiring colors. Your best bet might be to take the amp out and check. I turn my amp on with a 12v trigger and the "Turn-on mode" switch set to "rem" (remote, I guess).
Here's the manual:
https://www.cerwinvegamobile.com/man...eries-2015.pdf
V-man is offline
post #3 of 5 (permalink) Old 01-21-2018, 09:51 AM
Here's a link to the manual. It doesn't show the color of the wires, but you can see +/- for each channel in/out.
Use the remote turn on. HD sells a connector that makes this easy, about $10 if I remember correctly.
roadie13 is offline
post #4 of 5 (permalink) Old 01-21-2018, 09:58 AM Thread Starter
bigal51's Avatar
Thanks Guys, I have a manual But am still puzzled on the color code. I am taking the amp out today to make a final trim on the aluminum bracket I made. Since I posted I took a good look at the wire harness I bought from Biktronics and noticed that their color code going to the speakers are the same as the C V b-54 out put wires. I guess I could try just wiring color to color?
bigal51 is offline
post #5 of 5 (permalink) Old 03-19-2018, 09:03 PM
I don't know if you figured this out, but the color codes and the manual are confusing. Your answer is printed right on the amp where the speaker plugs insert.
bigal51 likes this.
Harleywood is offline
16 RGS rear speaker harness color code HD2fly Audio 3 07-18-2017 07:05 AM
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
speaker wire code gsbuick65 Audio 6 12-11-2012 07:47 PM
Andrews 54 versus SE259E PAC MAN Engine Related 5 03-10-2012 09:04 AM
Andrews 48 or 54 cam 2010fltrx Engine Related 10 04-05-2011 05:10 PM
