Help with finding a good small crossover - Road Glide Forums
post #1 of 5 (permalink) Old 01-29-2018, 09:46 AM Thread Starter
Heavy Metal's Avatar
I need a crossover that’s not any wider than 4” and 7-8” long max, and no thicker than @1.5” give or take. Something with 12db-24db and we’re the mid contour cuts off at 3.5Khz, with a Hi contour like this pics shows and like one that can give a hi boost but not a must, but can go from 20hz-28Khz and yes I know it’s all air up there and sub woofer below 50hz just want to follow the woofer and tweeter specs as well as can handle @200rms, 400 Watts. Any input be helpful
File Type: jpeg 2F307012-861F-445C-9C8F-CA4642290E77_1517240534943.jpeg (135.5 KB, 11 views)
File Type: jpeg C9FFA9D6-E62D-4CDF-9944-B39D23D1B3B8_1517240731286.jpeg (1.65 MB, 10 views)
Heavy Metal is offline
post #2 of 5 (permalink) Old 01-29-2018, 10:55 AM
Morningwood's Avatar
Did you buy everything from Biketronics I see they sell that speaker as an upgrade, if so call Mike at BT. He is extremely helpful and will probably be able to help you out.
Morningwood is offline
post #3 of 5 (permalink) Old 01-29-2018, 12:17 PM Thread Starter
The speakers were a gift
post #4 of 5 (permalink) Old 01-29-2018, 12:37 PM
Try him anyway he is a good guy and you bought their amp. I am pretty sure they sell that speaker as an upgrade, he will probably have some ideas. I probably should have responded to your other post and not this one.
post #5 of 5 (permalink) Old 01-30-2018, 07:05 AM Thread Starter
Send him email awaiting response I was thinking of putting the crossovers on top of one another behind radio on top headlight assembly like this:
https://youtu.be/f2u2F3c5yZo
A bit more help needed on crossover placement in a Road Glide Heavy Metal Audio 1 01-24-2018 07:03 PM
Need help with exhaust crossover BklynRGU Intake and Exhaust 1 04-20-2017 07:54 PM
need a little help finding my rear speaker wires mroach Audio 3 03-18-2012 08:30 AM
Help with finding a thread.... Kevian Controls & Handlebars 19 07-29-2011 11:56 AM
Need help finding a part or removing it. Ma$$hole *General Road Glide Discussions/Pictures 2 06-09-2011 09:37 PM
