mixing speakers - Road Glide Forums
post #1 of 12 (permalink) Old 02-01-2018, 09:01 PM Thread Starter
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
mixing speakers
Last year I installed an Arc Audio MPAK 12 on my 2016 FLTRXS. It sounds great, but I'm looking for more (louder better sound at 80 mph). This year, I invested in a set of lowers and I'm trying to figure out the second set of speakers. I have a couple of questions.
1. Should I mix different speakers between the upper and lower fairings?
If so, any ideas to match the Arc Moto 602's in the upper?
2. If I should stay with the Moto 602's, what is the difference between the 602 & 602v2? Are the v2's worth an extra $60 or $70?
Budget wise, $200 speaker vs $400 speaker? I'm OK with spending $400 to get a noticeably difference, but is it a $200 difference?
I understand the sound is very subjective, what sounds good to you may not sound good to me. I know some members have gone though dozens of speakers, Just looking for some advise, so I can narrow my selection down.
What am I listening to? Rock, Metal, Alt., Reggae, just about anything but that Techno B.S.
Thanks in advance.
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #2 of 12 (permalink) Old 02-02-2018, 08:29 AM
I am in a very similar situation, but with a couple small differences. Last year I purchased a Biketronics 4180 amp and the Arc 602v2s, for my '15 FLTRXS fairing. I went with the 4-channel amp because I got a good deal and wanted to be able to expand in the future. After awhile, I found that I needed more volume at 80mph so I tried a higher sensitivity speaker for my amp. I went with a pair of Polk MM652's and they are louder than the 602s but the sound is more harsh/sharp than with the 602s.
I just ordered color matched lowers with speaker pods for my bike so that I can experiment with the speakers I have in those two locations. My thought is that I will put the 602s back in the fairing to get the better sound quality in my face, and put the louder Polks in the lowers. We'll see what happens. Your budget is higher than what I had to work with, so I am sure someone with better bike audio knowledge can suggest some nicer speakers than the Polks.
Keep us posted!
macabra11 is online now
post #3 of 12 (permalink) Old 02-02-2018, 09:11 AM
The 602s are a great sounding coax speaker, but youíve found their weakness - after awhile you want more volume. The only way to go from here is some of the better component sets out there. Other coax speaks may be louder but will lack sound quality, itís all a trade off. Grab a set of DD AW 6.5 and a decent tweet and problem solved.
You didnít mention it, are you running the arc bridged? If not 150W isnít enough to make the 602s happy. 180 - 200W and they really come alive.
roadie13 is offline
post #4 of 12 (permalink) Old 02-02-2018, 10:00 AM
Morningwood's Avatar
I am using hertz sv165 in the lowers. These are midrange speakers which I am ok with as the fairing speakers are very bright. The have a high sensitivity and get very loud very fast. If you are looking for volume these are the way to go, loud and clear. If you are looking for a perfect sonic experience your gonna need to install a cage around the bike. The sv's do scream.
Morningwood is offline
post #5 of 12 (permalink) Old 02-02-2018, 11:22 AM
+1. The sv 165 are a great choice for lowers to add some fill. Not a fan on their own, but they compliment a full range front fairing speaker very well.
roadie13 is offline
post #6 of 12 (permalink) Old 02-02-2018, 02:01 PM Thread Starter
BubbaBeef's Avatar
No, not bridged. Audio is not one of my strengths. Didn't want to smoke a $1000 system.
post #7 of 12 (permalink) Old 02-02-2018, 02:08 PM
Itís easier to setup than you think. A basic multi meter is all it takes and the extra 30 or so Watts makes a noticeable difference.
roadie13 is offline
post #8 of 12 (permalink) Old 02-02-2018, 02:18 PM Thread Starter
BubbaBeef's Avatar
Correct me if I'm wrong. Bridging an amp will double the power and reduce ohms in half?
With the Moto 600.4, the bridged output would be 300 watts at 2 ohms? Isn't this more that the 602's can handle?
post #9 of 12 (permalink) Old 02-02-2018, 03:52 PM
It will put out 300W maximum at 2 or 4 ohm depending on switch settings (varies amp to amp). You are correct, they won't handle 300W. Just set the gains so that they're getting about 200W (28 V on the DMM) at the max distortion free volume - 14 of 17 bars on the infotainment system.
roadie13 is offline
post #10 of 12 (permalink) Old 02-02-2018, 06:13 PM Thread Starter
BubbaBeef's Avatar
OK, that makes sense. Thanks
Mixing and matching performance parts Road dawg Tech Area 10 03-27-2016 10:00 AM
Mixing Speakers sometimer Audio 2 02-22-2016 01:10 PM
Mixing impedance dmiller Audio 2 03-30-2015 10:19 AM
Harley mixing standard and metric too cyclotron *General Road Glide Discussions/Pictures 10 02-27-2011 03:44 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
