DSPís which is better or does best? - Road Glide Forums
post #1 of 5 (permalink) Old 02-09-2018, 07:07 AM Thread Starter
Heavy Metal's Avatar
So far two come up a lot, Rockford Forsgate DSP1, Arc Audio PCM, what else is there out thereanyone is running, Iím leaning towards the Rockford Forsgate DSP cause of app oriented vs computer based to run it. Iím not concerned with subwoofer system so itís not a concern, Iím also looking at 6 speaker set up that will consist of woofer/tweeter. The 7th/8th would be 6x9 or 8/8.8 component system so in need of correct 12-16 channels to control it unless using Y adapters for front vs rear R/L sides. Anyhow what do you think? And how has it worked out vs a crossover system, since crossovers consume more than Doing DSP way and pros and cons of both?
Heavy Metal is offline
post #2 of 5 (permalink) Old 02-09-2018, 07:58 PM
Brewiz's Avatar
I think you are over thinking this. What you are talking about is an active system on a motorcycle moving at speed, which is hard enough to tune in a car and would be impossible to tune on a bike.
Brewiz is offline
post #3 of 5 (permalink) Old 02-12-2018, 10:29 PM
madaba's Avatar
I chose to go with the Arc PSM based upon size to fit in the fairing despite the need to tune with a PC. Of course you're not doing this while it's moving... I don't have it finished yet so cannot comment on how works/sounds.
2017 Road Glide - Vivid Black
madaba is offline
post #4 of 5 (permalink) Old 02-13-2018, 09:19 AM
Get a hold of Alex at Bagger Audio Lab. He can answer all your questions about it.
phillyfan1 is offline
post #5 of 5 (permalink) Old 02-13-2018, 09:57 AM
madaba's Avatar
I will, he's who I bought it from
madaba is offline
Arc Audio PSM DSP catdaddy Audio 5 04-11-2017 12:16 PM
DSP or Line in converter dozer23 Audio 1 03-29-2017 07:23 AM
DSP... Digital Sound Processor Keiths HAWG Audio 16 02-23-2017 08:05 PM
Dsp dozer23 Audio 0 02-05-2017 09:06 AM
630w ROKKER Amp DSP Software UpGrade JMJOHN Audio 6 08-21-2016 02:23 PM
