Adjusting Gains - Road Glide Forums
 5Likes
  • 2 Post By Big_gary
  • 1 Post By BubbaBeef
  • 1 Post By Big_gary
post #1 of 8 (permalink) Old 02-11-2018, 02:59 PM Thread Starter
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
Adjusting Gains
I've been reading up on this for a few days and the more I learn, the more confused I get. So I'm looking for some help from the Audio Gurus. Here's my set up
Arc Audio Moto 600.4 amp
Arc Audio Moto 602v2 speakers in fairing
Hertz SV 165.1 in the lowers
I'm trying the set the gains using Ohms Law and a multi-meter. Bass and treble are 0'ed out, using a 1khz tone at 3/4 volume
V=sqrt(watts x ohms)
Question 1, what do I use for watts? RMS for speaker, max watts for speakers or the out put on the amp?
Question 2, assuming use RMS of speaker (602's are at question) which is 90 watts @ 4 ohms, I'm looks for 19 volts. I'm getting 26 volts with the gain at 0. Am I missing something here?
Thanks
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #2 of 8 (permalink) Old 02-11-2018, 03:33 PM
Thanks
Here is a cheat sheet for dummies. https://knowledge.sonicelectronix.co...l-multi-meter/
You use the Amplifier's watts in the formula.
Unless you have a oscilloscope , I prefer the old fashioned way.... by ear.
Brewiz and Mike U like this.
post #3 of 8 (permalink) Old 02-11-2018, 04:00 PM Thread Starter
BubbaBeef's Avatar
OK, use the watts output on the amp. This amp has 2 gain controls, one for channels 1 & 2, another for channels 3 & 4. Although they're different speakers, the gain will be the same?
Even using the amp's watts in formula, I should be looking for 24.5v. I'm getting 26v with 0 gain.
post #4 of 8 (permalink) Old 02-11-2018, 04:04 PM
You didn't read the dummy sheet. use each gain as like it's a separate amp. That means the total amps output are also divided in half for the sake of the formula.
post #5 of 8 (permalink) Old 02-11-2018, 04:13 PM Thread Starter
BubbaBeef's Avatar
Oh I read, but still confused as fuck
So on a 600w amp with 2 gain controls, I would use 300w in the formula?
Big_gary likes this.
post #6 of 8 (permalink) Old 02-11-2018, 04:27 PM
Yes you are correct .
Personally I don't like listening to music without bass/treble /eq. That's why I prefer the old fashioned way.
Set your gain at 0 with the Bass/treble/eq set the way you listen normally. Then adjust volume at 75% . Then slowly turn the gain up until you hear distortion then back off a few clicks. Now listen to several types of music you like to insure no distortion. If you need to back off a little more, do so.
This has always worked for me. Depending on where you got your test tone ,store bought or recorded you could be off more than by ear if the recording has been degraded,
Mike U likes this.
post #7 of 8 (permalink) Old 02-11-2018, 05:05 PM Thread Starter
BubbaBeef's Avatar
Thanks Big gary, I just had a moment of clairity
Just goes to show, an old washed up Cement Finisher still can learn a thing or two.
post #8 of 8 (permalink) Old 02-11-2018, 06:51 PM
Glad I could help sir.
Adjusting Gains On 4 Speaker System- Front and Rear scottrgs Audio 2 06-12-2017 06:50 AM
Help needed - Speaker placement and gains Sincecrazy Audio 4 02-05-2017 10:16 AM
Amp gains and final adjustment advice needed vinman4444 Audio 5 04-29-2014 06:13 AM
Dyno Day good gains! RKRGH *General Road Glide Discussions/Pictures 4 07-22-2013 06:10 AM
PBR300x4 Amp gains rdrnr03 Audio 3 04-22-2013 08:47 PM
