DSR1 questions - Road Glide Forums
post #1 of 8 (permalink) Old 02-22-2018, 09:43 AM Thread Starter
Heavy Metal's Avatar
DSR1 questions
It hooks between the radio and the amp, now I have a four channel I also have the component speaker system. The Hertz Millie MLK 1650.3. I have a Biketronics BT4180 amp. The amp can you do paralleling so you can put 8 speakers. Now how do I separate the tweeters for channels 1 & 2 and the woofers for channels 3 & 4 like in pic attached. And also be able to do the same thing in the rear part in the lidís component system separate tweeters separate woofer? So Iím able to run low pass I pass separating each one. Also and pick to which one of these from 2.0 to 4.0+ do I choose with a Biketronics amp In the stock 6.5 Harley stock radio on 2018 RGS.
File Type: jpeg 38EB9FD0-0C26-49ED-9CF7-E2ED37E92422_1519314053166.jpeg (471.4 KB, 29 views)
File Type: jpeg CEDE51A0-9DAE-4845-93B5-ADABF2AA93C1_1519314137601.jpeg (246.4 KB, 20 views)
Heavy Metal is offline
post #2 of 8 (permalink) Old 02-22-2018, 11:54 AM
DE-Glide's Avatar
The paralleling of the amp will be putting out the same frequencies/signal to both sets of speakers involved. In order to do what you are showing from the DSR1, you will need to run each set of speakers on their own dedicated channel (8 channels). The amplifier is simply outputting the signal it receives from the DSR1. You would need one set of RCA inputs for your tweeters, and one set for your mid bass drivers. In order to install the speaker and amp combo you have, use the included crossovers from the speakers. Set your high pass in the DSR1 for you mid bass driver. High Pass means it will let the Frequency you've selected and above to pass. The crossover included with the speakers will separate out the signal for the tweeters. It is no where near the control you would have if you were running each channel separately thru their own dedicated inputs on an amplifier. I am unsure of what voltage input you should be using with this particular set up. I could not find an info on what the output signal voltage is from the Biketronics line converter.
Ride More, Work Less
DE-Glide is offline
post #3 of 8 (permalink) Old 02-22-2018, 12:23 PM Thread Starter
The crossovers donít fit That came with the speaker system so I got me a DS18 seven crossovers
post #4 of 8 (permalink) Old 02-22-2018, 12:25 PM Thread Starter
Waiting to get it flashed so I wouldnít have to have the line levelers after that correct
post #5 of 8 (permalink) Old 02-23-2018, 08:07 AM
You do realize the 4180 has internal filters so what the dsr sends to it is getting changed correct
Outkast6991 is offline
post #6 of 8 (permalink) Old 02-23-2018, 10:10 AM
Where are you mounting it? Does it fit in a cubby?
roadie13 is offline
post #7 of 8 (permalink) Old 02-23-2018, 01:31 PM Thread Starter
Mounting it below amp, behind headlight...
What do you recomend rather than it since cannot use crossovers that came with speakers.
post #8 of 8 (permalink) Old 02-23-2018, 05:18 PM
Itís supposed to be great for flattening the signal and allowing you to eq. If I was in your shoes would just buy a different crossover that fits but keep the DS1.
roadie13 is offline
For '14 & up - BT355 line leveler & RF DSR1 Itzameeh Miscellaneous for Sale 0 08-04-2018 01:49 AM
For '14 & up - BT355 line leveler & RF DSR1 Itzameeh Parts for Sale 0 07-29-2018 01:07 PM
DSR1 question Heavy Metal Audio 1 03-16-2018 11:48 AM
Questions to ask Dealer re: buying bike joke *General Road Glide Discussions/Pictures 8 12-09-2009 01:07 PM
