Coaxial vs Companent. - Road Glide Forums
post #1 of 3 (permalink) Old 02-25-2018, 09:17 PM Thread Starter
Heavy Metal's Avatar
Just wondering which is better and why and which would be better with a DSR1 or other Digital sound processor? And work well with Biketronics 4180 amp at full power?
Heavy Metal is offline
post #2 of 3 (permalink) Old 02-26-2018, 05:09 AM
Donuts to donuts a component is better than a coaxial. Itís the physical construction. In a component setup each part (woofer and tweeter) does its own thing and does it very well. In a coax, one speaker must do both well so there has to be some sacrifice.
A good coax is always going to perform a tick or two below the same parts set up as components. Think of it like a vehicle. You can buy a sporty vehicle with 4wd, but itís not the same as having a corvette and a monster truck.
A DSP will work with either setup, but is best for systems where the woofer and tweeter each have a separate channel on an amp and the DSP controls each channel separately so it can be set to optimize each piece.
The DSP will still work fine if the woofer and tweeter are on the same channel because it flattens the signal and allows you to use the equalizer, itís just not as beneficial as doing each one separately.
Of course the real test is going down the road. Iíve never run a DSP with everything on its own channel so canít tell you how big of a difference it makes. In a parking lot or slow cruising Iím sure itís a massive difference. At speed Iím sure itís still better, the question is how much better and I donít know that answer.
Iím likely going to put a DSP on my CVO soon even though I really donít need it for a simple 4 speaker setup. I just want to try it.
roadie13 is offline
post #3 of 3 (permalink) Old 02-27-2018, 12:01 PM
DE-Glide's Avatar
The other benefit of running components through a DSP is that you can have more control of each, and you are using the DSP as a crossover. The included crossovers with component grouped speakers suck up power.
Ride More, Work Less
DE-Glide is offline
HERTZ HCX 165 6.5" 2-Way Hi-Energy Coaxial Speakers flaroadglide Audio 32 04-18-2015 01:51 AM
Component vs. coaxial speakers on a bike Spinnaker Audio 4 06-14-2014 08:03 AM
NEW SUPERSONIC SC-6905 6x9" 1200W 3-Way Car Audio Coaxial Speaker System PAIR Kevin0032 Audio 3 12-30-2013 02:29 PM
Arc Audio M.P.A.K. 4 - 6.5" Coaxial Speaker Kit daryl_db Parts for Sale 3 06-18-2013 12:01 PM
