DSR1 question - Road Glide Forums
post #1 of 2 (permalink) Old 03-16-2018, 07:36 AM Thread Starter
Heavy Metal's Avatar
DSR1 question
If I haven’t flashed radio yet will I need to run line levelers? I’m going to be running Hertz MLK 1650.3 with DSR1 tweeters on front and woofers on rear which would make it on the DSR1 tweeters channels 1 & 2 and woofers Channels 3 & 4, running a Biketronics Amp 4180, anything else I forgot? As in setting it to 3.0-3.5Vrms low level on DSR1 I’d having to still run live levelers and high level 4+ if don’t have to.
Heavy Metal is offline
post #2 of 2 (permalink) Old 03-16-2018, 11:48 AM
DE-Glide's Avatar
It appears as if the DSR1 accepts high level line inputs, so you shouldn't need line levelers in your application.
Ride More, Work Less
DE-Glide is offline
For '14 & up - BT355 line leveler & RF DSR1 Itzameeh Miscellaneous for Sale 0 08-04-2018 01:49 AM
For '14 & up - BT355 line leveler & RF DSR1 Itzameeh Parts for Sale 0 07-29-2018 01:07 PM
DSR1 questions Heavy Metal Audio 7 02-23-2018 05:18 PM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
