Added lower speakers and now problems - Road Glide Forums
post #1 of 7 (permalink) Old 03-18-2018, 03:34 PM Thread Starter
johnson27's Avatar
I have the Biketronics BT2180.14 amp, works great! I added lower speakers, plugged them in, got the bike all buttoned up and everything worked great. Took off on a ride today and about twenty minutes in, the right speakers, lower and fairing, have only static coming out. I did not have the system cranked loud, only about 4 bars on the volume. I did the radio reset, still nothing but static out of the right side. Anything like this happen to any members? Thought maybe I’d check here before taking the fairing off again and tearing into things. Thanks, John
johnson27 is offline
post #2 of 7 (permalink) Old 03-18-2018, 04:30 PM
BH#103's Avatar
I have money on the RCA cable. This happened to my set up using the RCA cable that was supplied with my Biketronics kit. I think from vibration the tangs on the plug end get looser and the right channel on mine would come and go. I replaced it with a Monster cable RCA and all has been great. I would pull the fairing and start diagnosing just in case I lost my money and it is not the RCA cable. If the cable looks fine and is still secure, try swapping the channels and see if you get static on the left side now and the right side sounds normal. Good luck, let us know what you come up with or if you need any help.
"SLIVER"
BH#103 is offline
post #3 of 7 (permalink) Old 03-18-2018, 04:55 PM Thread Starter
johnson27's Avatar
Sounds like a good place to start...thanks!
post #4 of 7 (permalink) Old 03-18-2018, 05:42 PM
Yep, with both sides going out dollars to doughnuts it's a loose connection. A lot of us are using the 18" stinger 4000 series off Amazon. Nice quality cable, very flexible, inexpensive, and they grab like a bear.
roadie13 is offline
post #5 of 7 (permalink) Old 03-19-2018, 08:09 AM Thread Starter
johnson27's Avatar
I just happen to have a spare line leveler, so, I will check all the connections tonite, and, if the sound is not restored, I may swap the leveler just to see.
Then, I'll call Biketronics and hope my amp isnt suffering from a blown channel.....
I really don't abuse this system so I hope its an easy fix.
post #6 of 7 (permalink) Old 03-19-2018, 05:57 PM Thread Starter
johnson27's Avatar
I took the fairing off and initially both rca jacks appeared to be fully seated in both the line leveler and the amp. I pulled the jacks out one at a time, reseated them and turned on the bike. Bingo! You guys were right, the white one (i think) must have wiggled loose as I can’t see where I would have created any ‘pull’ in the wires reassembling my headlight assembly or fairing. I’ve ordered the 18” stinger jacks. Thanks guys!!
post #7 of 7 (permalink) Old 03-23-2018, 06:00 PM
BH#103's Avatar
Glad you got it figured out, sounds so much better when you are hitting on all four speakers I'm sure.
"SLIVER"
BH#103 is offline
I added a Focal amp and speakers on my 15 RGS. Where do I get remote power? Major99 Audio 10 03-15-2015 12:50 PM
Added lights - now bike won't start Red Dawg Troubleshooting for Road Glides 10 08-19-2013 07:45 PM
Added ultra tour pack with lights, load problems? nashambassador48 Troubleshooting for Road Glides 3 06-28-2012 12:12 PM
Added the HD Bom Speakers and a Black Curved License Plate Frame Xaran Aftermarket Accessories 4 08-14-2011 09:09 AM
