Infotainment Problem - Road Glide Forums
 3Likes
  • 2 Post By Majaste
  • 1 Post By Willy_B
post #1 of 7 (permalink) Old 03-21-2018, 10:41 AM Thread Starter
Willy_B's Avatar
When i use my phone to play music via Bluetooth everything works fine as far as volume and tracking music from my hand control. If i plug my phone into the USB port in the glove box i can only turn volume up and down, not track through music. Anyone else have this problem or know what might be the problem?
Willy_B is offline
post #2 of 7 (permalink) Old 03-21-2018, 11:10 AM
Swomack's Avatar
Turn the scan switch on and you will be able to skip songs
I use a 64 gig USB stick & I use a i-Phone 7+ for all my music
Once your setting as set properly, the system works great
Good Luck
Swomack
My Gallery / Click Below Link
Swomack is offline
post #3 of 7 (permalink) Old 03-21-2018, 11:11 AM
Majaste's Avatar
Mine does the same thing, what happens is the Boom system can only read a folder or two deep into any "file system".
Imagine plugging a USB into a computer and viewing the contents of a file inside a folder and you'll quickly understand if you don't get that concept.
On a phone, your music files are pretty much "buried" and Boom cannot find its way to the music files to play them. So the system resorts to allowing you to use what it can control which at that point is only volume. Music selection will be manual like what you're doing now.
You will get a different response from a USB stick if the file type is correct (music format is one that Boom can understand) and placed on the stick in search able folders. You'll have full functionality with the hand controls at that point.
When using Bluetooth, you choose the file and the music plays directly from the phone to the system with no barriers. Plus the bluetooth connection itself controls forward/backward/volume/search functions.
A bit wordy but hopefully I explained thoroughly and you're not more confused...
Sent from my SAMSUNG-SM-G935A using Tapatalk
geo8866 and noneckg like this.
Majaste
Retired Air Force Munitions (1992-2015)
Majaste is offline
post #4 of 7 (permalink) Old 03-21-2018, 11:13 AM
Majaste's Avatar
Originally Posted by Swomack View Post
Tune the scan switch on and you will be able to skip songs
Swomack
That could work as well if the system doesn't have that much info to read! lol
Majaste
Majaste is offline
post #5 of 7 (permalink) Old 03-21-2018, 11:24 AM
WTFranz's Avatar
There is also a setting in your radio for the operation of the left joystick to either Scan or Seek. One will change stations/sources the other will skip from song to song on the same source. I think the default steps through your favorites. ie. Stations/sources.
I have 300 or so songs on my iPhone and never a problem when plugged in.
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #6 of 7 (permalink) Old 03-21-2018, 12:38 PM Thread Starter
Willy_B's Avatar
Thanks guys. Iíll check this stuff out. Had a buddy with 4 times as many songs on his phone try it out on his bike and it worked so i figured mine must be screwed up in some way either the radio or a setting.
Swomack likes this.
Willy_B is offline
post #7 of 7 (permalink) Old 03-21-2018, 12:58 PM
Majaste's Avatar
sounds like the setting of that left joystick is the way to go beyond the book explanation I wrote earlier! That's my geek side coming out...
Majaste
Majaste is offline
problem with infotainment painhealer New Members Welcome Area 0 03-18-2017 05:55 PM
InfoTainment GPS upgrades anyone?/ K1600FLHX GPS 44 11-09-2015 07:43 PM
Infotainment lock up mach65 *General Road Glide Discussions/Pictures 1 03-21-2015 06:46 AM
New Firmware for Boom Infotainment sblair *General Road Glide Discussions/Pictures 8 01-22-2015 04:06 PM
New Infotainment update is available on H-D.com sblair *General Road Glide Discussions/Pictures 22 12-04-2014 08:36 AM
