Cerwin-Vega B52 issues - Road Glide Forums
 5Likes
  • 2 Post By lonestardiver
  • 3 Post By tandemgeek
post #1 of 4 (permalink) Old 03-24-2018, 10:19 PM Thread Starter
UrbsValhalla's Avatar
I have a Cerwin-Vega B52 setup with a Biketronics BT355 line lever.
The issue I'm having is the AMP is not turning on with the stereo consistently. I have the Turn-on switch set to VOX. Sometimes the amp will turn on 10-15 seconds after turning on the bike. Other times it takes up to 30 seconds.
Do I need to run a remote wire and if I do what should I tap in to?
Thanks in advance for your assistance.
UrbsValhalla is offline
post #2 of 4 (permalink) Old 03-24-2018, 11:20 PM
From CV:
"The most preferred and reliable method is using the REM setting with a 12V trigger wire connected to the vehicles ignition..."
So yeah, I would do that. There was a 12V ignition activated accessory wire (maybe 18 gauge) in the harness of my Special located near the brake side directional connector- it was capped from the factory... blue if memory serves correct.
V-man is offline
post #3 of 4 (permalink) Old 03-25-2018, 08:06 AM
lonestardiver's Avatar
I used the power port/cigarette lighter power there in the fairing as the turn on signal...
Brewiz and Colin1966 like this.
lonestardiver is offline
post #4 of 4 (permalink) Old 03-25-2018, 08:23 AM
tandemgeek's Avatar
As the other two members noted, use the REM setting with an 18 ga signal wire tied into something like the cigarette lighter's positive lead using a T-connector.
tandemgeek is offline
What looks like B52 Cerwin Vega Amp paralleled Heavy Metal Audio 0 03-06-2018 09:54 AM
Cerwin Vega amp help. BigNorm Audio 19 01-14-2018 03:52 PM
Cerwin Vega B52 gazso19 Parts for Sale 4 05-05-2017 05:53 AM
Cerwin vega B52? Redrock Audio 16 03-21-2017 09:24 PM
Cerwin vega amp Bubba Audio 10 02-02-2012 09:37 PM
