How Much Amp Cable Needed? - Road Glide Forums
 2Likes
  • 1 Post By Colin1966
  • 1 Post By AndyFL
post #1 of 8 (permalink) Old 04-08-2018, 01:53 PM Thread Starter
Searched the forum for an answer but couldn't find one, sorry if this been asked before. Trying to find out about how much power cable will I need to install the amp on my 2015 RGS. I know the amp kits come with extra long cables, but I'm buying it by the feet. Running the 12V, fused 8 gauge cable from the faring, under the tank, to the battery. I guesstimated 4.5 feet long, does that sounds about right? As recommended by Rockford, I'm running the same path for my ground cable too. Thanks in advance.
AndyFL is offline
post #2 of 8 (permalink) Old 04-08-2018, 02:01 PM
Colin1966's Avatar
Run a string and measure the string.
Colin
madmat likes this.
Feb 14/1994-Nov 29 2012
Rest in Peace sweetheart.
Colin1966 is offline
post #3 of 8 (permalink) Old 04-08-2018, 02:09 PM Thread Starter
Aye, exactly what I did. Just wanted someone that has tackle this before to corroborate with me.
AndyFL is offline
post #4 of 8 (permalink) Old 04-08-2018, 02:12 PM
bucketlisthd's Avatar
A string will do it. Add a bit to the measurement, it can be cut.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #5 of 8 (permalink) Old 04-08-2018, 02:15 PM
Colin1966's Avatar
When I did my install I just pulled the tank and ran wires down the channel, easier than Fn around trying to hide wiring IMO
Colin
post #6 of 8 (permalink) Old 04-08-2018, 02:27 PM Thread Starter
Yes, this makes sense. I must likely buy 5 feet each to be on the safe side. Haven't pull out anything yet, just wanted to be 100% certain before starting to unbolt things. Thanks.
AndyFL is offline
post #7 of 8 (permalink) Old 04-08-2018, 02:29 PM Thread Starter
Colin
Can't agree with you more Colin. I wouldn't do it any other way.
Colin1966 likes this.
AndyFL is offline
post #8 of 8 (permalink) Old 04-09-2018, 01:29 AM
JacktheBagger's Avatar
ran mine that way on the 11 and it was close to six feet IIRC , more than you think it will be ..
2011 Ultra
JacktheBagger is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Decel popping - how much is too much? Methos1979 Intake and Exhaust 18 10-14-2015 03:58 PM
How much noise will too much runout cause? thedrill Engine Related 18 02-27-2014 02:52 PM
How much is too much...or is there such a thing? Chaz Audio 6 09-26-2012 02:49 PM
