WDX6Moto - Road Glide Forums
post #1 of 18 (permalink) Old 04-27-2018, 10:38 PM Thread Starter
Live2Ride's Avatar
WDX6Moto
I have a 2017 Road Glide Special. I picked up a set of DB WDX6Moto 6.5" speakers last week and finally got the chance to attempt installing these. I side by side compared them to the Kappas I had. At first I thought great these will fit perfectly...not so much. They are just a little taller which wasn't a big deal but in order to even get them angled in I had to remove the rubber grommet around the magnet. Once I did that they still would not fit flush and it's because the magnet is dam near as big in diameter as the speaker so they aren't going in. It looks like I may have notch the pods about a 1/8 inch for these to sit inside.
I have seen people use them on Street Glides but has anyone else used them on their Road Glides yet? Anyone have any suggestions? Also does anyone know somewhere I can get grills that are slightly raised over the stock?
Hopefully someone chimes in before I start cutting, lol. I plan to start back in on these probably Monday.
2017 Denim Black Road Glide Special
Live2Ride is offline
post #2 of 18 (permalink) Old 04-28-2018, 04:52 AM
Check the other forum. Lots of those guys running them, someone will chime in.
Do you have an adapter ring or dropping them straight in? The BT adapters are angled so the speaker is offset just a touch. Call mike at BT and he may know how they fit. Others make them as well.
There are pics (old so youíll have to dig, google as well) on the other forum of guys that have used a dremel to trim away a portion of the rib inside the pod. Other option is just cutting a rectangle notch out of pod where speaker hits and covering with dynamat or similar. IIRC that worked well for some of the Focals. Guys have also taken heat guns and reshaped pods, sounds like a pain though.
roadie13 is offline
post #3 of 18 (permalink) Old 04-28-2018, 10:17 AM Thread Starter
Live2Ride's Avatar
I want to drop them straight in so as to not raise them up any more because they would then not be able to put the grills on. I will probably end up doing the dremel route. If I could find some raised grills it would make it easier by making a rubber gasket to move them out further.
post #4 of 18 (permalink) Old 04-28-2018, 05:10 PM Thread Starter
Live2Ride's Avatar
I ended up cutting the pods. The tweeters are a little tall so the grills don't quite fit. That's ok though, I've been wanting to do something different with the grills. I'm going to cut out the inside of the grills and use the frame and put speaker fabric in.
post #5 of 18 (permalink) Old 04-28-2018, 05:25 PM
How much clearance do you need for the tweeters? The hawg wired metal grills have more room than the stock grills.
roadie13 is offline
post #6 of 18 (permalink) Old 04-28-2018, 09:44 PM Thread Starter
Live2Ride's Avatar
I searched Hawg Wired, nothing was listed for 2017. It's just barely a 1/8 inch. I already ordered speaker fabric it should give just enough stretch.
post #7 of 18 (permalink) Old 04-29-2018, 05:45 AM
Sorry, meant hog tunes.
RG RM Grills
roadie13 is offline
post #8 of 18 (permalink) Old 04-30-2018, 05:44 PM
ZX2BY2U's Avatar
Not sure if you've looked into this, but I was told the tweeter grills are removable. Didn't have to for my '07, but that my buy you a little clearance.
ZX2BY2U is offline
post #9 of 18 (permalink) Old 04-30-2018, 06:06 PM Thread Starter
Live2Ride's Avatar
Sadly, I wasn't aware of that but I'm ok with it, lol. My next post will show what I did. It's quite possible though because the 07 doesn't have the infotainment system there is a little more room.
post #10 of 18 (permalink) Old 04-30-2018, 06:18 PM Thread Starter
Live2Ride's Avatar
So I got the speakers in, I had to cut notches in the pods due to the magnet size and reworked the grills and I am so much happier with the outcome. I pretty much gutted the insides of the grills, leaving just the outside trim. This allowed me the space i needed to put a thin layer of hot glue down to to lay a piece of speaker fabric over top, the tweeters needed very minimal room to fit but due to the honey comb structure under the grills they wouldn't fit. I removed the rubber seal from underneath and that allowed me to fold under the fabric and hot glue it there as well. The only piece of the rubber I reused is for the larger triangle that insert under the fairing. I trimmed all the excess fabric away to clean it up. They fit great! and look good. The final picture shows some light coming through but that was because I hadn't yet put the outer fairing back on.
