Wired headset issues...kinda bizarre - Road Glide Forums
  • 1 Post By bosshogg123
post #1 of 7 (permalink) Old 05-19-2018, 01:00 PM Thread Starter
Few days ago I decided to test the wired headset that came with the RGU. Speakers worked, but mic did not. For phone calls.
Fast forward to today I went in for the first service. I asked the techs to test the headset. Thinking maybe I didnít have it configured properly.
We tried 4 H-D headsets all had same issue. The newer style with the 7-pin to 6-pin cable. None of them worked.
Then they tried an older style with the 7-pin to 7-pin cable. Worked perfectly.
They are going to contact H-D on Monday.
Just wondering if anyone else has had his issue? Also I have the WHIM installed but havenít broken down and purchased the H-D Sena headsets just yet.
Jeremy (Gulf Tango)
2017 FLTRU
gtmedic is offline
post #2 of 7 (permalink) Old 05-25-2018, 04:55 PM
If I am remembering right, the wired headsets aren't supposed to work after the WHIM is installed. This was discussed right after the WHIM came out. There was a thread on here about 20 pages long from back last summer. Perhaps you can find it. Had a lot of good info.
judgedelta is offline
post #3 of 7 (permalink) Old 05-25-2018, 07:50 PM Thread Starter
Thanks for that. The dealer didnít mention it I havenít heard from the dealer this week.
Thought I was being proactive by getting the WHIM but until they make an updated half helmet and WHIM compatible headset I am not spending $500.
Jeremy (Gulf Tango)
2017 FLTRU
gtmedic is offline
post #4 of 7 (permalink) Old 05-25-2018, 08:11 PM
bosshogg123's Avatar
Having been there myself, the wired headsets will still work on the RGU after the WHIM is installed; I used my Freewire with my Sena 10s until I got my HD 20s EVOs this spring and connected to the WHIM. In fact, since I usually rent a bike when I travel, Iíll keep my Freewire for that purpose...
gtmedic likes this.
bosshogg123 is online now
post #5 of 7 (permalink) Old 05-25-2018, 08:26 PM
I have a half helmet that I use with my 20s EVO; I picked up a set of earbuds to use with my Half helmet and it works great...
post #6 of 7 (permalink) Old 05-29-2019, 01:56 PM
Yes, same problem. I have a 2016 Tri Glide and a 2018 Ultra Limited. Installed WHIMS on both. Afterwards, the wired headsets do not work in the "mic" mode. For phone, intercom, CB (no Mic). Harley dealership couldn't figure it out. They tried newer headsets, but not any older ones. They said that was something I would have to live with- Harley didn't think that all the way through quality control.
Still have the same issue after a year.
taskmaster66 is offline
post #7 of 7 (permalink) Old 05-29-2019, 10:03 PM
craigffb's Avatar
Right from the HD web page.
It's time to cut the cord with your bike. Now available for '14-later Touring and Trike models equipped with Boom!ô Audio 6.5GT Radios, this Wireless Headset Interface Module (WHIM) lets you communicate with your bike without being wired to it. The WHIM Bluetoothģ adapter permits wireless connectivity to the 6.5GT Infotainment system, allowing you to communicate via CB radio, hear turn-by-turn GPS directions, listen to your favorite radio stations and so much more all through your Bluetoothģ-enabled headset. Impact of Retrofit on Wired Microphone Functionality: Upon installation of the WHIM, your motorcycleís wired microphone functionality will no longer be available. However, wired audio will continue to function as before.
https://www.harley-davidson.com/stor...terface-module
craigffb is offline
Answer calls using BOOM 6.5, but without HD wired headset? sirhomealot Audio 3 04-26-2018 03:48 PM
Nolan N104 wired Head set; Harley Headset and 3.5mm adapter. TRUBlue Miscellaneous for Sale 10 11-27-2015 06:38 AM
Wanted : HD wired headset Dmize Wanted! (Buy or Trade) 6 04-09-2015 06:26 AM
Issues with rear headset. Wildman Audio 4 05-28-2012 10:52 PM
