Need clarification - Road Glide Forums
post #1 of 5 (permalink) Old 12-17-2018, 06:37 PM Thread Starter
Richard SCB's Avatar
Need clarification
Hello, just need some basic advise. I have a 18RGS I am updating audio with bag lids & faring speakers.
I intend to use diamond 4v2 amp & hertz components.
Dose everyone guyst order the wire kits ? And do you all use a DSR ?
Also I see some guys use the rear channel and some dont?
Thanks .
Richard SCB is offline
post #2 of 5 (permalink) Old 01-10-2019, 09:59 AM
wevsspot's Avatar
IMHO the Diamond Micro4v2 is under powered to drive high quality front and rear 4ohm component speakers. It's a great AMP for bridging though.
Since you're spending a good bit of coin on Hertz component speakers, you might consider upgrading the AMP to the Arc Audio Moto 600.4.
wevsspot is offline
post #3 of 5 (permalink) Old 01-13-2019, 05:15 PM
Ndfastln's Avatar
I know there are a lot of fans of the Arc Moto 600.4 I am not one of them. I agree you need more power for that setup, but i would choose a different amp than the Arc. Something like a Focal FDP Sport, or Soundigital 1200.4 or even 2 micro amps like the Diamond Micro or Ground Zero GZRA Micro 4. Another option would be a Massive BLX 48.
If you are using the stock HU than you would see a benefit of a DSP, especially if you use the Soundigital or a Biketronics amp. If you don't you will need a BT 355 line leveler.
2007 SB Stage 1, PCV, 30/70 swap, fabbed fenders, w/ quick release bags fairing and tour pack, lots of powder, flake and marbled paint.
2008 Road Glide - Stage 1, added lowers and Tour Pak, and upgraded audio.
Ndfastln is offline
post #4 of 5 (permalink) Old 01-13-2019, 05:55 PM
Welcome to the forum. As was stated the 4V2 is underpowered in 4 channel mode so you'll want something different.
What exactly do you mean by "hertz components"? That will drive amp recommendations.
You can use a DSR1 any time with the stock head unit but it's kind of overkill for a 4 speaker system.
You can have the flash done to activate the rear channel and use 2 line levelers or just use RCA Y connectors and get away with 1 line leveler. I've done it both ways and prefer the Y connectors just because it's cheaper. My dealer does the ultra flash for free so I still have fade if needed.
roadie13 is offline
post #5 of 5 (permalink) Old 01-14-2019, 11:11 AM
wevsspot's Avatar
Agree on your alternate AMP recommendations. Everything suggested are solid performers.
wevsspot is offline
Clarification from Service Manual on testing fuel gauge '98 RG Driftah Troubleshooting for Road Glides 1 10-01-2013 01:33 PM
Daymaker Install Advice Clarification Lucky D Lighting 4 03-12-2013 09:16 AM
Clarification Needed Jeffdag *General Road Glide Discussions/Pictures 10 07-03-2012 12:16 PM
Need clarification on HK rear speaker pins SickRick Audio 6 01-15-2012 05:32 PM
