in-line converter?, wt heck is that for? - Road Glide Forums
 3Likes
  • 1 Post By Mike U
  • 1 Post By Mike U
  • 1 Post By Luckys2018RoadGlideCustom
post #1 of 8 (permalink) Old 12-25-2018, 10:27 PM Thread Starter
Luckys2018RoadGlideCustom's Avatar
What is a in-line converter?
When is a in-line converter used on a motorcycle?
What is its purpose?
Thanks
John S
Luckys2018RoadGlideCustom is offline
post #2 of 8 (permalink) Old 12-26-2018, 03:46 AM
Mike U's Avatar
John, a simple answer is it changes a radios wiring from high to lo allowing the use of RCA Connections.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 8 (permalink) Old 12-26-2018, 11:45 AM Thread Starter
what do u mean by hi to low
please explain some more?,lol....(I want to learn!),lmao
When you say 'changes'..What do you mean by 'changes'?
What are you changing?
And why are you changing it?
And why do you change to RCA lines?
post #4 of 8 (permalink) Old 12-26-2018, 08:32 PM
Mike U's Avatar
John, the below listed information comes from Sonic Electronix.
I hope this helps.
Mike U.
High-Level (Speaker Level) Inputs:
Speaker level inputs are commonly referred to as high-level inputs and vice versa. Some amplifiers will have special adapters with bare wire at the end, this wire will connect to your speaker wires. Speaker level inputs are used when you want to connect an amplifier to your factory radio or an aftermarket radio that does not have low-level (RCA) inputs. It allows you to use the signal coming from the speaker outputs as an input source for the amplifier.
Low-Level (Line Level) Inputs:
Line level inputs, also known as RCA inputs or low-level inputs, use RCA interconnect cables to link the amplifier with the source unit. Most aftermarket radios have multiple pairs of RCA outputs that can connect to multiple amplifiers. Factory radios, even those with stock amplifiers, often do not have low-level inputs so these are used mostly with aftermarket setups.
Is there a difference in sound quality between the two input methods? Factory stereo systems connected with high-level inputs will not sound as good as low-level inputs. If your using an aftermarket stereo, there wonít be much of a difference between high-level or low-level inputs on basic systems. If youíre going higher end use low-level inputs. Often times high-level inputs are connected incorrectly and as a result there is signal degradation. Because high-level inputs require that you splice into your vehicle wiring, some users forgo that option and prefer to run the RCA cables instead. These input methods give great flexibility when installing into vehicles regardless of their system type.
NorthlandRider likes this.
USMC 1975-1977
Semper Fi!
post #5 of 8 (permalink) Old 12-27-2018, 06:46 PM Thread Starter
wow! did not know that
holy crap
ty so much
I think Im sticking with low level. The simple answer, in a nut shell, connections are clean and easy, dont need to solder, and greater flexibility, just to name a few.
post #6 of 8 (permalink) Old 12-27-2018, 11:00 PM
Mike U's Avatar
Youíre very welcome John.
I hope I was able to assist you.
If you have any other questions donít hesitate to ask.
You can always PM too.
Mike U.
USMC 1975-1977
Semper Fi!
post #7 of 8 (permalink) Old 12-28-2018, 05:41 PM Thread Starter
converter questions
Thanks Mike appreciate it
Happy New Year
..the audio bug is upon us and it has bit me..Im trying to learn as much as possible
Mike U likes this.
post #8 of 8 (permalink) Old 12-28-2018, 07:00 PM
Mike U's Avatar
Happy New Year
Thanks and Happy New Year to You also Brother!
Mike U.
USMC 1975-1977
Semper Fi!
DSP or Line in converter dozer23 Audio 1 03-29-2017 07:23 AM
PBR300 and Line Out Converter BlkRat Audio 2 02-13-2016 08:06 AM
Wt trade Kerryebro Classifieds Archive (3 months old+) 0 06-12-2011 06:24 PM
where the heck can i find a set of 10" monkey bars in stock? Steveg Road Glide Specific Discussions 8 05-13-2011 07:30 PM
One heck of a gang.... TracyB General Off-Topic Discussions 11 04-22-2011 09:38 PM
