FYI 2015-2019 cubby hole size in fairing ARE. - Road Glide Forums
post #1 of 7 (permalink) Old 01-12-2019, 05:06 PM Thread Starter
Heavy Metal's Avatar
Update. Can’t get 2 Biketronic BT4180 amps into the fairing.
BUT
The cubbies are 4.250” aka 4 1/4”.
They will support
Diamond Audio Micro4V2 in each.
Cerwin Vega B54.
MATTS Audio Pro amp MD4110
Now which ones to use in cubby.
Like CVO I’ll put the BT4180’s into each bag.
2 DSR1’s in fairing.
That would work.
Heavy Metal is offline
post #2 of 7 (permalink) Old 01-13-2019, 04:47 PM
Ndfastln's Avatar
Have you tried using a Lex Rivera amp mount? It allows 11 1/4" long 8" wide and 2 1/8" tall.
2007 SB Stage 1, PCV, 30/70 swap, fabbed fenders, w/ quick release bags fairing and tour pack, lots of powder, flake and marbled paint.
2008 Road Glide - Stage 1, added lowers and Tour Pak, and upgraded audio.
Ndfastln is offline
post #3 of 7 (permalink) Old 01-13-2019, 06:43 PM Thread Starter
Nope, have you?
post #4 of 7 (permalink) Old 01-13-2019, 08:58 PM
Is that the fairing mount that vertical by the fork leg?
Buzzy is offline
post #5 of 7 (permalink) Old 01-13-2019, 10:31 PM
Ndfastln's Avatar
Yes I've used it before, but not for 2 BT 4180's. Here is a pic of it with a Soundigital 1200.4:
Ndfastln is offline
post #6 of 7 (permalink) Old 01-13-2019, 10:47 PM
Ndfastln's Avatar
The Soundigital is almost twice the size of a 4180, so 2 MIGHT fit on the tray. The next time I get one I'll try it as I have 2 4180's and a 4250 in stock. It MIGHT also be possible to fit one under the radio and one on top of the headlight using that tray. I know you can fit a Soundigital 800.4 on top of the headlight, and the dimensions are very close to a 4180.
Ndfastln is offline
post #7 of 7 (permalink) Old 01-14-2019, 09:58 PM
Ndfastln's Avatar
I took some measurements of the 4180's. It would be tight but looks like they would fit side by side. I also set an Arc Moto 600.4 there for comparison.
Ndfastln is offline
2015 RGU CVO vs 2019 RGU Prolific *General Road Glide Discussions/Pictures 26 09-23-2018 01:34 PM
2015 speaker size suicidecj5 Audio 1 07-20-2015 01:18 AM
Fairing bolt size? HogPro *General Road Glide Discussions/Pictures 7 06-16-2013 12:49 PM
what size is largest amp for inside fairing?? FUGLY Audio 1 07-10-2011 12:35 AM
