FRONT speaker wiring?? - Road Glide Forums
 2Likes
  • 2 Post By roadie13
post #1 of 5 (permalink) Old 01-18-2019, 08:33 PM Thread Starter
Luckys2018RoadGlideCustom's Avatar
Whats up guys,
I have a question I was wondering I could ask you guys...On the wiring kit I received from AmericanHardbag, I received 2 sets of front speaker install wires. Any idea why I have 2 sets of speaker connectors for the FRONT speaker pods?
1) The first set is labeled "Speaker Connectors for Front Speaker Pods".
So I received 2 sets of quick disconnect plug n play harness wires in 1 bag.
At 1 end of the cable it has 1 quick disconnect and at the other end it has a wire that has not been spliced open yet. When I spliced open the other end there are two wires, 1 of which is red and the other 1 of which is black.
The other quick disconnect harness contains the same color coded wires as the first harness, 1 of which is red and 1 of which is black also.
2) The 2nd bag contains the label "14' and UP Harley Front Speaker to RCA kit"
And that contains 2 seperate quick disconnect harnesses with an RCA plug at one end and at the other end it contains these little black resistors wrapped in heat shrink.
So, I'm a bit confused, which one of the sets of front speaker cable inputs am I going to use ? or do I use both of those? and Im assuming since the first set of quick disconnects ,at the other end it contains 2 separate red and black wires, Ill be soldering something onto that or onto another wire?
So, which one am I using? Or do they both go together?
Bit confused?
Thanks guys,
John S
Luckys2018RoadGlideCustom is offline
post #2 of 5 (permalink) Old 01-19-2019, 04:22 AM
Assuming you bought the amp and speakers from them #1 is probably the wires that will go from amp to speaker and #2 is probably wires that would go from bike front speaker harness to amp input. Probably won’t need #2 because of DSR1 but don’t trash them, they may come in handy later.
Call me later and we’ll walk through it.
RFG7680 and duglauraflht like this.
roadie13 is offline
post #3 of 5 (permalink) Old 01-31-2019, 07:16 PM
Mike U's Avatar
Hey John did You ever get Your Audio System all squared away?
Keep us posted on how it turns out.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #4 of 5 (permalink) Old 02-02-2019, 05:29 PM Thread Starter
audio upgrade status?
Hey Mike, Im still working on it!?
Im currently working on the front channel
Ill keep you guys posted
its a bit tricky my man
but we hope to get her done soon!
John S
post #5 of 5 (permalink) Old 02-02-2019, 05:32 PM
Mike U's Avatar
John S
Good Luck Bro.
If you need any further assistance don’t hesitate to ask.
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
CVO 15 front speaker lids edimean22 General Off-Topic Discussions 5 11-23-2018 06:58 PM
Are You Adding a Tourpak to your 2015 RG? nking262 Equipment-RG 39 07-02-2016 02:28 PM
2015 Amp and Speaker install *write up* Shaner87 Audio 48 12-22-2015 08:07 AM
cross over - blown speaker - question RGUrider Audio 2 09-25-2015 03:38 PM
Speaker level wiring to amps FLTRXpilot Audio 8 07-15-2013 11:20 AM
