Sony AX5000 with Amp - Road Glide Forums
post #1 of 3 (permalink) Old 02-02-2019, 06:48 PM Thread Starter
I've just purchased the Sony AX5000 head unit from Fathead Cycles. I also am installing a Cerwin Vega B52 amp and Infinity Kappa speakers. I'm a little stumped on how the amp connects to the speakers. Do I run the speaker wires from amp directly to speakers bypassing the original connections? If so, what happens to the original connection? Any insight would be very appreciated. Audio is new to me but how are going to learn if you don't try?
Thanks and may God bless
CMA Hollywood
1CMAHollywood1 is offline
post #2 of 3 (permalink) Old 02-02-2019, 07:09 PM
CMA Hollywood
If your connecting the Sony to the Amp via rca cables (low level) you won't use the speaker connections on the Sony. You may also need to go into the software of the Sony and turn off the internal amp. You'll then run speaker wires out of the amp straight to the speakers.
post #3 of 3 (permalink) Old 02-11-2019, 11:01 PM Thread Starter
Thanks for the info! I've been out of pocket but I did get the system up and running!
Thanks again for the help!
Sony ax5000 ordered. Sgt Goody Audio 23 05-28-2018 05:05 AM
Brand new Sony ax5000 direct drop in double din Sgt Goody Parts for Sale 2 05-24-2018 07:34 PM
