Connections - Road Glide Forums
 2Likes
  • 1 Post By roadie13
  • 1 Post By RoadGlide18
post #1 of 8 (permalink) Old 02-13-2019, 01:27 PM Thread Starter
Heavy Metal's Avatar
Connections
When connecting amps does negative always go to negative on a battery for all amps or some negative wire goes to frame ect? To growing it?
Heavy Metal is offline
post #2 of 8 (permalink) Old 02-13-2019, 02:00 PM
Most manufacturers recommend a short ground to frame because they’re dealing with a car which has plenty of good and accessible grounding points. Most guys go all the way to battery because of bikes (especially older ones) having poor grounds. I’ve done both and never had an issue, but I go all the way to the battery more often than not.
duglauraflht likes this.
roadie13 is offline
post #3 of 8 (permalink) Old 02-13-2019, 03:15 PM
duglauraflht's Avatar
Always ran it back to the Battery leads....Frame secondary or even as close to the triple trees...Battery is a sold point.
duglauraflht is online now
post #4 of 8 (permalink) Old 02-13-2019, 04:00 PM Thread Starter
Now my Biketronics BT4180 is connected to a radio screw I guess grounded to the bike but I’m going to be putting Cerwin Vega B54 Amps to runs my tweeters so should I ground same place or go to batter negative?
post #5 of 8 (permalink) Old 02-13-2019, 04:09 PM
RoadGlide18's Avatar
For the best noise immunity going back to the battery negative is the best. Keeps you away from ground loops.
JK
RoadGlide18 is offline
post #6 of 8 (permalink) Old 02-13-2019, 05:13 PM Thread Starter
Explain the ground loop or should I say refresh me on it. And second I should attach a extension on BT4180 and move ground to the battery negative as well?
post #7 of 8 (permalink) Old 02-13-2019, 06:16 PM
On the BT amps just leave the ground as is, especially if you're not having issues with fuzz or background noise. They have always come with the short ground wire and I've never had a problem. If you have enough wire run the B54 to the battery.
roadie13 is offline
post #8 of 8 (permalink) Old 02-13-2019, 06:42 PM Thread Starter
I’m going to put the BT4180 into the saddle bag like they do amps in the CVO’s in back of saddle bag. So I’ll have to run negative ground wire to battery negative right?
Tour Pak speaker and light connections sullyjoe Aftermarket Accessories 1 09-20-2011 07:29 AM
Tour Pak speaker and light connections sullyjoe Troubleshooting for Road Glides 0 09-16-2011 08:44 AM
