RGU amp suggestions - Road Glide Forums
 3Likes
post #1 of 36 (permalink) Old 02-13-2019, 09:11 PM Thread Starter
RGU amp suggestions
I’m looking for advice on an amp that will fit under the faring and will be powerful enough to push four quality coax speakers. I am not looking for the cheapest thing I can find but I don’t have unlimited funds either. I’m not set on speakers yet but I would guess I would need something in the 100w RMS/channel @ 4 ohms area. Thanks in advance for any responses.
Researching Road Glides
eggwhite93 is offline
post #2 of 36 (permalink) Old 02-13-2019, 10:16 PM
Ndfastln's Avatar
A Soundstream PN41000D is a good budget amp that pushes a verified 140wX4 @ 4 ohms.
A Stinger SPX700X4 would be a step up in sound quality
A Focal FDP Sport may be a bit overkill, but even better.
A Soundigital 1200.4 is an other good sound quality option.
2007 SB Stage 1, PCV, 30/70 swap, fabbed fenders, w/ quick release bags fairing and tour pack, lots of powder, flake and marbled paint.
2008 Road Glide - Stage 1, added lowers and Tour Pak, and upgraded audio.
Ndfastln is offline
post #3 of 36 (permalink) Old 02-14-2019, 03:42 AM
Heavy Metal's Avatar
Biketronics BT4180. Plug and play.
RFG7680 likes this.
Heavy Metal is offline
post #4 of 36 (permalink) Old 02-14-2019, 03:49 AM
RFG7680's Avatar
Yep.
I have a special and installed a BT2180.15 plug and play kit.
Never did one before. Super simple. No fuss muss.
RFG7680 is online now
post #5 of 36 (permalink) Old 02-14-2019, 08:07 AM
duglauraflht's Avatar
Don't be in a hurry, research every suggestions and or feedback given to yah here...Lots of good choices.
Diamond Amp
Cerwin Vega amp
Biketronics is solid both 2180-4180
Focals
Soundstream
Rockford Fosgate 400.4
Good luck...
duglauraflht is offline
post #6 of 36 (permalink) Old 02-14-2019, 02:31 PM
wevsspot's Avatar
Decent setup
Cerwin Vega B54 or Diamond Audio Micro4v2
Infinity Kappa 62.IX (the speaker choice is important here because the Kappas are 2 ohm with a good sensitivity rating)
If you plan on 4 Ohm speakers I'd recommend one of the other AMPs already suggested
Rockford Fosgate TM400X4ad (very good mid range $ AMP)
Stinger SPX700X4 (very good mid range $ AMP)
SounDigital 1200.4D (very good mid-high range $$ AMP)
Biketronics (I'll leave the comments about pricing empty since BT does offer a discount to forum members and they do offer complete kits)
Focal FDP Sport (fantastic AMP but $$$ expensive)
Arc Moto 600.4 (fantastic AMP but $$$ expensive)
Depending on the AMP you choose you'll have two mounting options if you want to keep it in the fairing. Under the radio or above the headlight assembly. There are a couple of different AMP mount brackets available if you want to go under the radio, or you can rig something up yourself.
The Cerwin Vega B54 and Diamond Audio Micro4v2 will fit on top of the headlight like they were designed to sit there.
wevsspot is offline
post #7 of 36 (permalink) Old 02-14-2019, 02:47 PM
Cerwin Vega B54 fits the cubby holes in front fairing also like Diamond Micro4 V2
post #8 of 36 (permalink) Old 02-14-2019, 06:45 PM
If you run the sound digital you need a DSP, just something to consider. The Focal amp has gotten strong reviews and is a powerhouse. I have the Stinger amp and its a nice amp. Pushes the MMatts really nice.
Budget dictates where you go from here.
Wevsspot was dead on with his suggestions
phillyfan1 is offline
post #9 of 36 (permalink) Old 02-15-2019, 04:00 PM Thread Starter
Thanks for all the suggestions so far!
These are the two setup that are leading right now after way too much reading both here an on the other forum. Could you guys please let me know what you like between these two and also give other advise if you think there is something else out there I may want to check out.
Set up #1
Stock head unit
BT LL Ultra kit
CV B54
4 Kappa 62ix speakers
Set up #2
Stock head unit
BT LL Ultra kit
SS PN4.1000d
4 Polk MM652 or Hertz HCX 165
I’m looking to stay under $800 and also want to stick with a 4 coax set up for now.
BTW I do know the challenges involved in fitting the PN4.1000d under the fairing of the RG and I'm ok with that.
Thanks!
post #10 of 36 (permalink) Old 02-15-2019, 04:30 PM
bucketlisthd's Avatar
That amp might be a real challenge. It was all I could do to stuff a SS 52OD in my Rushmore.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is online now
4 Channel AMP Suggestions FLTRXS18 Audio 2 01-12-2015 05:56 AM
West Virginia Suggestions panhead Road Trip Discussions/Stories/Pictures 4 04-01-2014 08:40 PM
Picking up 13 FLTRU Sunday. Suggestions? Mountainman *General Road Glide Discussions/Pictures 46 11-02-2013 05:53 AM
Suggestions request DeanFLTRX Controls & Handlebars 3 08-11-2013 12:18 PM
Suggestions wanted: new head unit HellInABucket Audio 21 06-24-2013 08:52 AM
