Front channel bridge..will it handle it?and DSR1 specific setup? - Road Glide Forums
post #1 of 4 (permalink) Old 02-19-2019, 12:03 AM Thread Starter
Luckys2018RoadGlideCustom's Avatar
Hey guys, I’m back on, quick question...I own Hertz Mille Pro X165.3 at 4ohms impedance these pump out at 200 watt peak,100 watt continuous sound on the speakers ( I have no idea to begin to tell you if the 200 watt figure I presented just now is for a bridged amp or not)?..and with a DIAMOND 4v2 600 watt 4 channel- ( bridged at 2 channels is 300 watts/ per side),( front channel only). and a Rock Fosgate DSR1-signal processor and my stock Harley head unit?
First question I got, is bridging doable with those speakers , I mean they wont blow or anything will they?
Last question, does anybody know if you program a processor to run on a specific setup for your bike and then decide to bridge your front channel, does the signal that is coming out of your radio going to push the DSR1 , ( in my situation), or any signal processor to work harder and run the risk of damaging it in the long run if your always blaring it on 100 all the time?
Luckys2018RoadGlideCustom is offline
post #2 of 4 (permalink) Old 02-19-2019, 09:26 AM
wevsspot's Avatar
I can't answer the DSR question, but as for the speaker power handling capacity.....................
Bridging the Diamond Micro4v2 works perfectly pushing the Hertz speakers. Can you blow the speakers?.............. Of course you can, but there isn't much risk as long as you set your system up correctly and don't intentionally try to burn them down. Distortion kills speakers quicker than clean power does - always. Just because the Micro4v2 is capable of outputting 300W per channel in bridged mode, doesn't mean that you have to crank the gains all the way up and try to achieve that claimed max power output. For simplicity sake, a clean 200W at 2/3 of an AMP's capability is a better solution than trying to hit 200W with another AMP that has less power and that would need to operate at 100% of it's rated power output to hit that number.
Set your gains correctly, by ear, o-scope or even DMM, lock her down and enjoy the new audio system.
wevsspot is offline
post #3 of 4 (permalink) Old 02-23-2019, 03:06 PM
I have a diamond 4v2 on the way and was wanting to know how to bridge it for just 2 front fairing speakers.
johnt69 is offline
post #4 of 4 (permalink) Old 03-06-2019, 06:25 PM Thread Starter
ty so much!
you are a lifesaver as well!
spring is almost here!
seasonal depression is a motherf^&%er!, hahahaha
Take care
John S
does large front tire handle well for touring? kwcommando *General Road Glide Discussions/Pictures 20 01-30-2019 01:43 PM
Front brake handle hard to pull firewalker17 Do-IT-Yourself 2 03-20-2017 05:30 AM
Front and Rear Suspension Setup dinggus Suspensions 29 03-16-2017 02:56 PM
On ebay: '02/'13 with 180 front tire setup SMSgt B Bikes for Sale 6 08-01-2013 03:55 PM
Only front speakers installed...each speaker on it's own amp channel? modot66 Audio 14 02-27-2012 06:53 PM
