4 speaker audio set up possibly 6 - Road Glide Forums
 9Likes
post #1 of 18 (permalink) Old 02-28-2019, 07:58 PM Thread Starter
Looking for recommendations I know the options are endless right now looking to run a 4 speaker set up don’t know if the 6 is worth it doing lids on bags. Have the lowers with 6.5 just waiting to buy speakers and amp what route would you guys take. Do not want to do this twice searching for the best for the buck have around a $1000-1500 for the set up. Cruise at 80mph have side dump turnout what would be your recommendations.
Thanks, Justin
jrees407 is offline
post #2 of 18 (permalink) Old 02-28-2019, 08:50 PM
With all of the times Ive added to my system, do it once and do it right. When you get into 6 speaker systems, a DSP is not mandatory but I would suggest it.
Do you want to go with co-ax, pro audio speakers?? Where do you want to put the amps? You doing the install yourself?
Need to listen to as many bike systems as you can and figure out the sound you like, then go from there.
Piece together your system to maximize dollars and quality.
phillyfan1 is offline
post #3 of 18 (permalink) Old 02-28-2019, 08:55 PM Thread Starter
Amp will be in the fairing will be doing install myself yes.
duglauraflht likes this.
jrees407 is offline
post #4 of 18 (permalink) Old 03-01-2019, 08:56 AM
Mike U's Avatar
Justin, I am by no means an Audio Guru but I just went through purchasing a lot of new equipment for my 2012 Roadlide so I did a ton of research.
Right now the Beyma's, PRV's and MMats are the Hot Ticket Speakers but can get pricey.
Other good speakers are Focal and Hertz.
Depending on how you like your music will help you choose which ones to go with.
As far as Amplifiers, Digitaldesign 800.4, Focal FDP Sport are the top of the line for motorcycles but expensive.
JL Audio, Stinger, Cerwin Vega and Sound Stream make some very affordable amps.
Don't forget that you will also need wiring to connect your amp and speakers.
Make sure to use 100% Oxygen Free Wire, it's the best for audio.
Do "The Google" search for some well informed info.
Hope this helps.
Best of Luck.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #5 of 18 (permalink) Old 03-01-2019, 10:01 AM
Glidin2013's Avatar
Sorry. Tried not to, but can't help myself... With that exhaust setup. Earbuds and bluetooth... Doesn't really matter. 3-5 years of riding with that pipe and loud music and it won't matter. You won't be able to hear sh*t anyways...Ask me how I know.. I am running a FF 4 speaker inner fairing. Have 4 mids and 4 tweeter setup pushed with Arc 600.4 amp running right in my face. I still have tough time sometimes knowing if the next song playing is AC/DC or ABBA, 'cause I can't hear anymore. Not that I listen to ABBA. Just saying two totally different genres of music. If you under 40 never mind, you probably won't get the ABBA reference. The guys on here will give you the info you are looking for, along with the smart-ass inputs like mine. You are right. With that exhaust and cruising speeds, lid speakers are a waste. You are going to want a lot of power pushing speakers that need/like a lot of power to get the volume I think you will need. My .02.
Glidin2013 is offline
post #6 of 18 (permalink) Old 03-01-2019, 11:23 AM
That exhaust is going to kill just about any system at HWY speed. Missed that part
Brewiz and Mike U like this.
post #7 of 18 (permalink) Old 03-02-2019, 07:24 PM
SEsupply2's Avatar
Originally Posted by jrees407 View Post
Looking for recommendations I know the options are endless right now looking to run a 4 speaker set up donít know if the 6 is worth it doing lids on bags. Have the lowers with 6.5 just waiting to buy speakers and amp what route would you guys take. Do not want to do this twice searching for the best for the buck have around a $1000-1500 for the set up. Cruise at 80mph have side dump turnout what would be your recommendations.
Thanks, Justin
take at a look at SOUNDZ on Facebook or contact Peter Jensen on there, he is the owner. Read his reviews, and his knowledge about stereo equipment for your bike. He is the man to turn to.
www.soundzbaggeraudio.com
2018 FLTRXSE, Freedom 13" windshield, SOUNDZ amp, Iron 65 fairing & lower speakers, Iron 57 saddlebag speakers, Fullsac MX pipe, CVO power cores, Corbin dual touring seat, Ohlins 159 shocks, JH Choppers Performance floorboards, Pingel floorboard extenders, King tour pak w/chopped backrest, Metalsport luggage rack, Ciro3d cupholders, Avon grips
SEsupply2 is offline
post #8 of 18 (permalink) Old 03-03-2019, 06:37 AM
Read the OPs post again. His budget is a no go for your suggestion. He can get more for way less if he pieces it together and doesn't get a "Kit".
Brewiz, Bevis and eggwhite93 like this.
post #9 of 18 (permalink) Old 03-03-2019, 12:33 PM Thread Starter
Im not trying to compete in any sound comps or anything just looking for a very clear and decently loud sounding system. Usually listen to country/metal pretty much my genres of music yes rap here and there but rarely maybe some of the older stuff. Decided I will have a 6 speaker setup going to be running two in the fairing, two in lowers, and 2 6x9's in lids the hardest part of this i suppose is making the speaker decision. Since the fairing and pods both accept a 6.5 speaker would it be stupid to run the same for speakers in all to make it easy.
jrees407 is offline
post #10 of 18 (permalink) Old 03-03-2019, 01:11 PM
Very subjective question. You will want your best sound quality in the fairing. get that set first and then go from there.
So many speaker amp options out there its nuts. The trick is choosing speakers that all work together.
Research. Research. Research
Data Dump: Audio Thoughts, Opinions, & Experience Welcome DeathProof Audio 8 12-07-2017 03:51 PM
No Cage Audio Christmas Sale sloride Audio 4 12-16-2016 08:43 AM
NO Cage Audio Black Friday Sale sloride Audio 30 11-28-2016 08:14 AM
Boom Audio Fairing tweeter grills and speaker SurlyBoy Parts for Sale 0 06-18-2015 11:46 PM
HD Boom Audio Saddlebag Speaker kit part #76000202 2stangs8689 Parts for Sale 6 11-16-2014 08:59 PM
