Ax5000 into my 2017 - Road Glide Forums
 3Likes
  • 1 Post By ashnic
  • 1 Post By Willy_B
  • 1 Post By ashnic
post #1 of 10 (permalink) Old 03-17-2019, 06:16 PM Thread Starter
ashnic's Avatar
Ax5000 into my 2017
Got a full biketronics
Sony AX5000 kit to go along with the biketronics amp, infinity front speakers and Pioneer 6x9 in the bags that I had been running with the boom radio. Got everything installed which was a pretty straight forward install. Put everything back together and crazy issue with hand controls..push left thumb control towards tank=volume down, push right thumb control in is volume up, nothing else does anything? Is there something I may have missed in the install? I started messing with Sony Custom controls but could not get anywhere..I would program left thumb down for vol. down, then try to do up for vol up and said I can not use same control...something seems screwed up but I don't know how..it's pretty much plug and play...any help would be greatly appreciated..
2017 Road Glide Special
ashnic is offline
post #2 of 10 (permalink) Old 03-17-2019, 07:20 PM
gldlver's Avatar
Got mine from Fathead Cycles, had control sync worked perfect, no Idea what type of system Biketronics has but the Metra kit had a Block that was programmed for the controls that gave you a series of LED blinks to confirm.
gldlver is offline
post #3 of 10 (permalink) Old 03-17-2019, 08:05 PM Thread Starter
ashnic's Avatar
Nothing came with the Biketronics unit to sync anything..It was suppose to be a pretty much plug and play...it aint!
ashnic is offline
post #4 of 10 (permalink) Old 03-17-2019, 08:35 PM
gldlver's Avatar
maybe contact Fathead and see if they can send you the other parts needed which is a Metra HD-ASWC-1 handlebar control integration module
https://fatheadcycles.com/collection...ug-play-bundle
My kit from them took 20 minutes to install to full audio and control.
gldlver is offline
post #5 of 10 (permalink) Old 03-18-2019, 09:11 AM
BH#103's Avatar
Contact who you got it from before anything else and ask them what's up. It may not be the same interface wiring as the one from Fathead so it may not help, but if you get no help from the seller I'd check out the videos on the Fathead website. Maybe it is the same setup. The part that gets programmed on the Fathead setup is called an AWSC-1 or something similar.
"SLIVER"
BH#103 is offline
post #6 of 10 (permalink) Old 03-18-2019, 09:51 AM Thread Starter
ashnic's Avatar
Going to give Biketronics a call this morning..it does have a large red module for the hand controls...will see what's up...
ashnic is offline
post #7 of 10 (permalink) Old 03-18-2019, 12:13 PM Thread Starter
ashnic's Avatar
Called Biketronics and in about 15 mins everything is working as it should. Mike showed me how to reset the module and we are making sweet music again...pretty much unplug the module, let it sit for a min plug back in...
Willy_B likes this.
ashnic is offline
post #8 of 10 (permalink) Old 03-18-2019, 12:57 PM
Willy_B's Avatar
Glad to hear you got it worked out. Did you get the magnetic rain cover with it? I’m thinking about getting the same unit but I’d only get it from biketronics cause of the cover
koryu2u likes this.
Willy_B is online now
post #9 of 10 (permalink) Old 03-18-2019, 01:53 PM
gldlver's Avatar
good to hear its all working
gldlver is offline
post #10 of 10 (permalink) Old 03-18-2019, 07:37 PM Thread Starter
ashnic's Avatar
Yes..I got the rain cover..seems pretty nice..fits very good. Nice storage bag as well to keep it in..
koryu2u likes this.
ashnic is offline
2017 RGU Fairing Accessory Switches Harley Rider *General Road Glide Discussions/Pictures 8 09-18-2018 07:37 AM
Gypsy Tour 2017 HUTMO ARCHIVES-SWVII Cherokee 9 04-06-2017 11:21 AM
Lack of windshields for 2017 Road Glide dshudson *General Road Glide Discussions/Pictures 14 02-10-2017 09:10 AM
Factory 47 16" on 2017 Need to know chriscalabro Controls & Handlebars 4 01-26-2017 09:35 PM
