J&m acoustic pads. - Road Glide Forums
post #1 of 5 (permalink) Old 03-20-2019, 09:52 PM Thread Starter
J&m acoustic pads.
I was looking at the J&M acoustic pads for my 05 rg and I figured they are fairly inexpensive so I initially planned on giving them a try. I have a aquatic AV head unit, kenwood 400w amp, a set of Polk 6.5Ē speakers in the stock position, and a second set of Polk 6.5 mounted in the inner fairing behind the storage compartments. I get distortion at anything over 1/2 volume and I donít know enough about it to know if my speakers are underpowered or overpowered (sorry, I went off on a tangent). Anyhow, I read a review about the J&M acoustic padding possibly causing the amp to overheat. It was just the one person and I canít find anyone else talk about it. Does anyone have any experience with them that they can pass along to me?
Springer042 is offline
post #2 of 5 (permalink) Old 03-21-2019, 07:55 AM
Are your gains set properly? If so, how did you set them?
I wouldn't buy those things. I wouldn't use them if they were given to me
phillyfan1 is offline
post #3 of 5 (permalink) Old 03-21-2019, 08:29 AM
Brewiz's Avatar
I lined the inside of my outer fairing with this to get rid of the hollow sound I had. You can cut and shape it then apply it with 3m spray adhesive.
https://www.parts-express.com/acoust...-foam--260-318
Brewiz is offline
post #4 of 5 (permalink) Old 03-21-2019, 10:25 AM Thread Starter
Itís a lower end amp with no adjustment for gains. Iíve messed with the adjustment on the head unit a lot and it is way better than stock, I just feel like it should be better. Iím mostly concerned about amp overheating than anything when it comes to this stuff. I was hoping someone could confirm or deny that aspect.
post #5 of 5 (permalink) Old 03-21-2019, 07:52 PM
Hey there I have all the J&M Rokker stuff in my 08 , I initially did the amp and speakers then when I put daymakers In I added the acoustic padding , made a difference for me as it keeps the sounds from projecting forward and bringing them more back toward the rider. That’s my opinion on them and as far as overheating goes,the sound damping pad does not cover any area where air would come inside the fairing anyways.The 40 bucks spent made my sound better in my bike.
Jlegters 86 is offline
Replacing Rear Brake Pads w/ Lyndall pads 1st Sgt Do-IT-Yourself 20 08-25-2013 04:57 PM
acoustic pads linngrovian Audio 38 07-05-2013 06:41 AM
J&M Inside Fairing Acoustic Speaker Pads FLTRXS18 *General Road Glide Discussions/Pictures 7 07-03-2013 09:32 PM
Brake pads KIWIHOG Wheels and Tires 9 06-26-2012 09:00 PM
J&m fairing acoustic pad harley davidson fltr 98-10 NakedSnowman Audio 0 06-07-2011 10:02 PM
