Sena, Cardo, or Wired? - Road Glide Forums
 16Likes
post #1 of 40 (permalink) Old 03-28-2019, 10:37 AM Thread Starter
texasnurse's Avatar
So first of all Iím not spending $600 plus install on a WHIM and HD 20s evo setup.
Iím debating on adding a wired mic and earbuds to my helmet along with adapter to the stock radio.
Or go the wireless route and continue to not use the features built into the radio.
I have searched on this forum and would like some opinions; perhaps from RGU owners that use the wired sets.
I should also mention I daily commute to work...
2018 RGS
texasnurse is online now
post #2 of 40 (permalink) Old 03-28-2019, 10:42 AM
Little Wing's Avatar
the only experience i have is with the cardo.
it worked. and it was wireless. and it was bluetooth compatible.
there's no way i would spend that kind of money on a whim/hd system
'18 FLTRX ē '04 BAR HOPPER ē '94 FLSTC ē THE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #3 of 40 (permalink) Old 03-28-2019, 10:44 AM
craigffb's Avatar
I use a wired headset on my bike. I plug it in and it works...EVERY TIME. Add on top of that you can get wired Harley headset for like $50 cause people are dumping them brand new cheap to go wireless. The Harness with the DIN plug is like $65. I even built a rear harness so my OL and I can use the inter comm.
JGray and ChromeSpark like this.
craigffb is offline
post #4 of 40 (permalink) Old 03-28-2019, 11:51 AM
Dragonback's Avatar
I concur.. Its the least expensive and most successful way to connect.. a) without whim and HARLEY ISSUED headset you cannot hear Stereo (from what I heard) if you use 20s directly to phone, thats ok.. but then you cant use all features or radio specifically voice commands..
Simple to install. Only one minor fault I see with way Harley asks you to install.. an Craig please let me know if I misread or did something wrong..
As part of the install they ask you to use the double stick tape to keep Port nicely on tank.. I might be wrong but I think this will make it difficult if you need to remove tank again for another reason. if you ran cables under "wiring tunnel" under tank .. if you didn't, guess you can put tank aside while you work but it will still be "attached" via this port. I didn't taped it so its a little wiggly but I don't mind (talking about the port that is ... )
Also, if you go wired, i would recommend getting a helmet that has the place for the ear pods.. if you dont have one already... makes for a more comfortable ride..
BTW.. Sena make a "Freewire" device thats less then WHIM and allows stereo.. you could research that... Law Abiding Biker on youtube has a good review of it..
Craig.. also, if you read this,
can you let me know how you setup the rear harness.. will be much appreciated.
ChromeSpark likes this.
Black Bike Matters !!!
They say.. Its not What you ride ... but That you ride.. guess they aren't riding a Harley!
Dragonback is offline
post #5 of 40 (permalink) Old 03-28-2019, 12:10 PM
craigffb's Avatar
@Dragonback
Here is where I mounted the riders DIN on my last two bikes.
Here is the passenger DIN.
If youíre wanting to do this PM me and Iíll help you out as much as I can. There were dudes who did it before I did, but when I was trying to do it I couldnít get any help. Itís not hard to do just takes a little time.
craigffb is offline
post #6 of 40 (permalink) Old 03-28-2019, 12:16 PM
RFG7680's Avatar
I almost went the 20s WHIM route. Took it back. Picked up a nice used Sena S20 and bluetooth to my phone only. I listen to my music via the fairing speakers. Didn't need it to do 100 things. I'm ok with the bike GPS. And if I want to I can use my phone GPS and it comes through my sena speakers in my helmet. Considering the freewire. But not seriously.
RFG7680 is online now
post #7 of 40 (permalink) Old 03-28-2019, 03:10 PM
Dragonback's Avatar
@Dragonback
Hey Thanks... Looks good.. PMing you..
post #8 of 40 (permalink) Old 03-28-2019, 06:22 PM
Some very good info posted so far. For me, I have done the Bluetooth connection with my phone. Installed the wire setup from HD on my 15 RG and as stated, it always worked, but after a while I got tired of messing with the wire. Used J&M, good headset and helmet speakers - but just mono with the HD head unit. Decided to bite the bullet and go with the WHIM and the HD wireless headset and do not have any regrets at all.
For me, if I ever get another new/newer bike, I will remove the WHIM and put it on the next bike. If you decide to go with the wired setup, I would suggest taking a look on an auction site and pickup a center console with the opening for the wired headset. HD offers the wire setup to install on a bike that did not have it from the factory. Take that cable and add about 8Ē to it, that way you will be able to run the wire under the tank in the wiring tray under the tank, like it would come from the factory, than up to the console mount.
FLTRXS18 is offline
post #9 of 40 (permalink) Old 03-28-2019, 06:31 PM
Willy_B's Avatar
This is the exact same boat Iím in as far as what i want one to do. Thinking i may pick up a new sena 10s though.
Willy_B is offline
post #10 of 40 (permalink) Old 03-28-2019, 08:18 PM
Pete1's Avatar
Anyone have luck with the sena 10U pad bluetooth for the HJC is max2 helmet?
Pete1 is offline
Added SENA Freewire and Harley Headset Plug bulldawgfan Audio 2 05-13-2018 07:31 AM
Bluetooth Woes bikepsych Audio 4 05-05-2017 12:54 AM
Sena SPH10 Bluetooth Headset & Intercom Swomack Audio 16 10-06-2016 07:46 AM
Cardo Customer Service #1!!! HeatWave Companies We Can Recommended! 2 08-30-2014 04:02 AM
Sena SMH10R Bluetooth Tytanium *General Road Glide Discussions/Pictures 7 06-20-2013 02:13 PM
