6 speakers off one amp?? - Road Glide Forums
  • 1 Post By Quickrunner
post #1 of 10 (permalink) Old 04-01-2019, 11:46 AM Thread Starter
Is there a small amp that will fit in an 05 fairing out there that can drive 6 speakers? Setup is two speakers in stock location, two 6.5's cut in fairing by forks, and two 6x9's in lids. Currently have 2 small amps (hogtune & RFpbr) that I would like to replace with one single more powerful amp that can drive 6 speakers. Thanks
lonestardiver likes this.
Quickrunner is offline
post #2 of 10 (permalink) Old 04-01-2019, 02:30 PM
lonestardiver's Avatar
Depends on the impedance of the speakers...
Are they 8 ohms, 4 ohms, or 2 ohms?
How low of an impedance is your amp stable to ?
Is it 1 ohm stable, 2 ohm stable, 4 ohm stable ?
lonestardiver is online now
post #3 of 10 (permalink) Old 04-01-2019, 02:31 PM
Also are you going to use a 2 channel or 4 channel amp?
post #4 of 10 (permalink) Old 04-01-2019, 05:30 PM Thread Starter
Looking to replace existing speakers and the 2 small amps, listed above. Looking for suggestions.
post #5 of 10 (permalink) Old 04-01-2019, 06:41 PM
Brewiz's Avatar
Also what's your budget?
Brewiz is offline
post #6 of 10 (permalink) Old 04-01-2019, 07:21 PM Thread Starter
Economy, thats why I was thinking Polk MM speakers & Cerwin Vega amps. Decent bang for the buck
post #7 of 10 (permalink) Old 04-01-2019, 08:55 PM
Personally Id run a 4 channel amp in the faring for the fronts and 1 in the back for the 6x9s. I know that is not what you are looking for.
The impedance of the speakers is important so we can determine how they could be wired to attain the impedance that a prospective amp can support.
A two channel amp can do it...more speakers requires more power.
If the amp is not stable at the impedance the speakers present then it will shut down or blow.
So we are back to the speakers.... pick some and lets us see how we can make it work...
post #8 of 10 (permalink) Old 04-02-2019, 10:27 AM Thread Starter
I believe I stated Polk MM would work for my budget. I think they are 4ohm. I have not bought anything yet. Just looking for options other than just replacing the RF amp and waiting for it to blow again.
post #9 of 10 (permalink) Old 04-02-2019, 10:55 AM
If the speakers in front are 4ohm and wired in series and then the rear in parallel you have a net 2.6667 ohms impedance. So you would need a 2 Ohm stable amplifier if you went with a 2 channel amp.
300 watt 2 ch amp (2 Ohm stable)
This puts 100 watts to the front speakers and 200 watts to the rear 6x9s.
All in series
Or you can run all speakers in a channel in series with a net 12 Ohm impedance which allows you to run a 4 Ohm stable amp (2 channel) which will make it easier to find an amp that will fit.
Your power will be evenly divided between the speakers.
A 100 watt amp will result in about 16.7 watts per speaker.
300 watt amp is about 50 watts per speaker
This gives you some info on what to look for in a amp besides size...
post #10 of 10 (permalink) Old 04-05-2019, 03:24 PM
Spazz's Avatar
I run 4 Carbon 65's and 2 Iron 69's off a DSP and SS4.100 amp... Faring, lowers and lids 4 Carbons are paralleled into the front 2 channels creating a 2ohm load. The Iron 69's are 2 ohm load and run off the rear 2 channels.... perfect setup. Sounds incredible.
RENO BAGGER AUDIO
Spazz is offline
JBL GTO 638 speakers NickyNuts Audio 1 01-13-2017 04:03 PM
Speakers and Amps gplatt58 Sold 13 02-11-2015 05:50 PM
Replaced Stock Speakers with J&M Rokkers ZXPilot Audio 13 08-19-2014 03:42 PM
General audio upgrade information, long dres22 Aftermarket Accessories 13 03-09-2014 09:05 AM
question for the audio pros about speakers and amp DED HD Audio 6 11-06-2011 01:17 PM
