CV B54 advice - Road Glide Forums
post #1 of 11 (permalink) Old 04-04-2019, 02:49 PM Thread Starter
CV B54 advice
One of my Kappa's kicked the bucket on my ride back from Fl last weekend.
Was running the 62.ix @2.5 ohms and they sound great.
Has anyone ran this amp with 4ohm speakers. Only running fairing speakers, and thinking of trying something different.
2018 FLTRX
Sent using Tapatalk
Justin29365 is offline
post #2 of 11 (permalink) Old 04-04-2019, 03:25 PM Thread Starter
Or maybe some JBL GX602, real cheap in case another one bites the dust and 150 watt rms
2018 FLTRX
Sent using Tapatalk
post #3 of 11 (permalink) Old 04-04-2019, 04:23 PM Thread Starter
Well messed around with it some more and found if I loosen the negative terminal on this speaker 1/4 turn it plays just fine, as I go to tighten fully volume goes down and finally off when fully tightened down. So for now I will leave it 1/4 backed out and try to look for a different seat of fairing speakers.
Have already trimmed speaker wire back thinking maybe it was crimped and same issue, swapped speakers to opposite sides and swapped RCA around and that did not help. Maybe the plating on the bottom of the terminal has peeled off or something cannot tell from just looking into terminal hole.
Will be doing some more research to see what pair to order, would order another pair of Infinity's but these aren't even 6 months old yet and already having this issue....rather try something else.
post #4 of 11 (permalink) Old 04-05-2019, 03:30 AM
The B54 is fine with 4 ohm speakers. For a 2 speaker setup Iíd bridge it. IMHO itís underpowered in 4 channel mode, only around 90 W or so if Iím remembering correctly.
roadie13 is offline
post #5 of 11 (permalink) Old 04-05-2019, 08:40 AM
bosshogg123's Avatar
In 4 channel mode, the B54 is rated at 150w per channel at 2 ohms and 75w at 4 ohms, definitely makes sense to bridge it if youíre running two 4 ohm speakers.
bosshogg123 is offline
post #6 of 11 (permalink) Old 04-05-2019, 07:02 PM Thread Starter
Would be 300x2, so I would still be running 150 per speaker?
Also I am guessing use both rca on amp but can I still use just the one Biketronics line leveler? Just use one RCA from ea Chanel, either Left or Right.
2018 FLTRX
Sent using Tapatalk
post #7 of 11 (permalink) Old 04-06-2019, 06:06 AM
In bridged mode there is 300W available to each speaker.
Yes, you can split the signal and use one line leveler.
roadie13 is offline
post #8 of 11 (permalink) Old 04-09-2019, 07:08 PM
Roadglide19's Avatar
I have the Polk MM652 Marine speakers in my bike. I’m using the CVB52 and a line leveler and they sound clear as a bell at 80mph at 3/4 volume. I could crank it higher if needed and not get distorted. Cost effective and quality sound.
Roadglide19 is offline
post #9 of 11 (permalink) Old 04-10-2019, 03:15 PM
wevsspot's Avatar
Justin,
If you're going to run a pair 4 ohm speakers I highly recommend bridging the B54. You won't be happy with the volume level of the 4 ohm speakers if you don't.
A recommendation before you go spending money though.............
I know you said that you stripped the speaker wires again and tried it with the same results. If you didn't tin the bare wires with solder I'd try that first. Strip the wires leaving about 1/2" bare wire. Tin all leads. Then reconnect the speakers and test.
wevsspot is offline
post #10 of 11 (permalink) Old 04-10-2019, 04:13 PM Thread Starter
Originally Posted by wevsspot View Post
Justin,
Found the issue, tried soldering the wires but this post keep vibrating down as I ride causing the speaker to quit playing. Can pull it up and it plays but after riding awhile and hitting bumps it vibrates back down and the speaker goes off again.
Well looks like I swapped the speakers around the last time I pulled them, the one with no issue had its wires soldered. Pulled the speakers today after riding and the one side cutting out again, cut the wires and soldered all the wires for each speaker. Will see how it does on my next ride, if it still starts cutting out will be looking for something else.
File Type: jpg 56277940_10157375579329474_4681369393198792704_n.jpg (43.0 KB, 15 views)
Advice on best equipment for sleeping roadside? 2000roadglide *General Road Glide Discussions/Pictures 43 08-06-2017 06:34 PM
Revamping audio system. Need some advice JayKS Audio 11 11-14-2014 11:43 AM
accident advice boudie *General Road Glide Discussions/Pictures 20 10-19-2011 10:42 PM
Advice for my first long ride??? Dmize Road Trip Discussions/Stories/Pictures 40 05-31-2011 04:59 PM
Headin North and Need Some Advice... gzrglide09 Road Trip Discussions/Stories/Pictures 2 07-16-2010 11:12 AM
