2019 GTS Boom! Update issue - Road Glide Forums
post #1 of 13 (permalink) Old 04-07-2019, 10:55 PM Thread Starter
S.curtis's Avatar
Went to install latest firmware for my 2019 RGS, got an error message that the update was interrupted and to turn the ignition to accessory and reinsert the usb. Not sure what happened to cause the error, now the radio is stuck with the error message and the touch screen wont allow the highlighted resume button to activate with either using the touch screen or the joy stick.
Anyone else have this happen and any advice?
2019 Road Glide Special, 2008 Sportster
If you can read this Thank a Teacher
If in English Thank a Soldier!
S.curtis is offline
post #2 of 13 (permalink) Old 04-08-2019, 07:03 AM
Erilflynn's Avatar
[QUOTE=S.curtis;4612939]Went to install latest firmware for my 2019 RGS, got an error message that the update was interrupted and to turn the ignition to accessory and reinsert the usb. Not sure what happened to cause the error, now the radio is stuck with the error message and the touch screen wont allow the highlighted resume button to activate with either using the touch screen or the joy stick.
Anyone else have this happen and any adDid it actually give you the message if you want to start update and, if so, how far did it get when it says it was interrupted? I think there was 6 modules and they were all fairly quick (which was the XM one)...that one took like 10 minutes before it said it was done. You did wait until it said it was done, right?
2019 Road Glide
2016 Street Glide Special (Gone)
2015 Kawasaki 1700 Voyager (Gone)
Erilflynn is offline
post #3 of 13 (permalink) Old 04-08-2019, 07:32 AM Thread Starter
S.curtis's Avatar
It never got to that point, I started the update with the usb drive and went on to doing other things in the garage when I came back after a bit probably half hour that was the message on the screen and now regardless of what I do it wont change.
S.curtis is offline
post #4 of 13 (permalink) Old 04-08-2019, 07:43 AM Thread Starter
S.curtis's Avatar
[quote=Erilflynn;4612975]
With he new touch screen Iím not sure how to do a hard reset to try to clear and start over?
S.curtis is offline
post #5 of 13 (permalink) Old 04-08-2019, 07:52 AM
Swomack's Avatar
Sounds like you need to take it in to the dealer and let them figure it out.
Man what a pisser
Swomack
My Gallery / Click Below Link
Swomack is online now
post #6 of 13 (permalink) Old 04-08-2019, 08:15 AM Thread Starter
S.curtis's Avatar
Man what a pisser
Swomack
Iím afraid your correct
S.curtis is offline
post #7 of 13 (permalink) Old 04-08-2019, 09:00 AM
Erilflynn's Avatar
Before you walked away, did it ask and did you tell it to do the update?
2019 Road Glide
post #8 of 13 (permalink) Old 04-08-2019, 11:51 AM Thread Starter
S.curtis's Avatar
I did and it had started
S.curtis is offline
post #9 of 13 (permalink) Old 04-09-2019, 09:43 AM
wevsspot's Avatar
Since it's still under warranty I'd be tempted to take it to the dealer and let them deal with it. If you feel like trying a couple of things before that option;
1. Remove the USB, pull the main maxi-fuse (large red fuse located under the left side cover) for 3 to 5 minutes, reinstall the fuse and see if the system resets.
2. Remove the USB, attempt to enter diagnostic mode and reset the radio back to factory defaults and then try the update again.
wevsspot is offline
post #10 of 13 (permalink) Old 04-13-2019, 08:18 PM Thread Starter
S.curtis's Avatar
Well got the radio issue corrected today at the dealer, between myself and the tech we figured it out. Had to pull the fairing disconnect the radio, pulled what look like a SIM card and put it all back together. Finally the radio rebooted with the memory stick installed. Finally completed the update. Wow what a mess. But all seems to be fine now. Thanks tor all the suggestions and help.
PG
S.curtis is offline
What did you learn about your 2019 BOOM BOX GTS today Paul's Road Glide Tech Area 24 12-12-2018 07:57 AM
2019 BOOM radio crazy4ink Tech Area 17 11-09-2018 09:35 AM
New software update available for Boom Box ynotbmester *General Road Glide Discussions/Pictures 59 05-15-2018 10:12 AM
Boom Audio rant Jhl192 Audio 3 11-18-2016 10:02 AM
new 12 RGU... downshifting issue? pfd161 *General Road Glide Discussions/Pictures 23 03-27-2012 09:09 PM
