Amp power kit or DIY? - Road Glide Forums
post #1 of 5 (permalink) Old 04-11-2019, 09:16 PM Thread Starter
big papa's Avatar
You guys buying a premade/measured power wire and fuse holder kit or make your own? How long does the wire need to be from battery to amp on radio? What gauge for DA micro4v2. What size fuse? Thx.
big papa is offline
post #2 of 5 (permalink) Old 04-12-2019, 09:37 AM
wevsspot's Avatar
For some reason I never buy the kit............... Might be foolish but oh well. Here is my standard list;
wire
fuse
ring terminals
maxi-fuse
40A
wevsspot is offline
post #3 of 5 (permalink) Old 04-12-2019, 06:06 PM
Mike U's Avatar
One thing to look for in Audio Wire is that it is 100 % Oxygen Free.
It may be a little more expensive but you will hear a difference with Audio.
Just my 02 cents.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #4 of 5 (permalink) Old 04-12-2019, 06:34 PM
Mike U's Avatar
Big Papa, I'm not sure of the length of wire needed for the Newer Models of Glides but I am in the process of upgrading my 2012 Custom and I bought everything I needed on Amazon.
I did a lot of searching and reading and was able to put together my own list of necessities.
It does get a little costly as opposed to purchasing a kit but I like to make sure I have some of the best equipment when it comes to my Glide.
Here is a list of the Audio Accessories I am using.
Hope this helps.
Mike U.
NVX 4GA 100% Oxygen Free Power and Ground Cable
NVX XRTC4 4Gauge Solid Copper Ring Terminals
NVX 8GA 100% Oxygen Free Amplifier Cable
NVX 16GA 100% Oxygen Free Speaker Cable
NVX XW1850BL 100% Oxygen Free Remote Turn On Cable
Stinger SPD5625 Fused Positive Distribution Block
Stinger SHD21 Ground Distribution Block
Stinger SPD 5101 Fuse Holder
Wire Ferrules
USMC 1975-1977
Semper Fi!
post #5 of 5 (permalink) Old 04-13-2019, 06:33 AM
Scosche makes a nice kit for about $40. If I was doing a ton of installs I’d buy it separately but I only do a few a year so kits are easier for me. IIRC 3 ft is plenty, 4 is overkill.
If it’s just the one 4V2 than 8ga wire and 60 amp fuse are fine. The amp has an internal 50 amp fuse so needs to be bigger than that.
roadie13 is offline
New Dynojet Power Vision CX for H-D fuelmoto Fuel Moto 1 02-22-2018 01:27 PM
Boom! Audio Amp Removal Question ace1usmc Audio 22 05-11-2016 10:14 AM
Retuned...again apgharleymech Dyno Results 51 05-04-2016 01:01 AM
Aux Power Question buzzman_45011 Aftermarket Accessories 13 11-15-2011 05:40 PM
Custom Mod - 12V Power Socket in Right Glove Box Tytanium Do-IT-Yourself 14 10-28-2011 11:03 AM
